Author Topic: What did you and your MKV do today?  (Read 3475516 times)
Offline Southy_
« Reply #8805 on: February 01, 2016, 08:37:51 am »
Fitted this
Where did you buy it from/how much did it cost? If you don’t mind me asking.
Patrick2691
« Reply #8806 on: February 01, 2016, 09:01:58 pm »
Gave it a clean up inside and fixed my dash cam wiring :happy2:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8807 on: February 01, 2016, 09:13:14 pm »
Fitred Cruise Control in but have issues programming it.  :stupid:
Offline Newbieintown
« Reply #8808 on: February 02, 2016, 09:28:23 am »
What's the problem dude?
200bhp
Tornado Red
2006
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8809 on: February 02, 2016, 10:12:15 am »
My clone vagcom hasn't got the login button in 01 engine controller. :sad1:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8810 on: February 02, 2016, 06:57:43 pm »
Managed to program the CC in the end. don't know why it didn't accept the coding last night but today it worked out fine and now I have CC on the golf   :smiley:
Thanks again Newbieintown  :drinking:
Offline RedGolfDom
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99951.0.html
« Reply #8811 on: February 10, 2016, 07:00:14 pm »
Finally got round to doing the boot pop mod and love it!
Mk5 golf gt 140
Revo stage 1
Air lift Performance 3p
Offline white91
« Reply #8812 on: February 10, 2016, 07:03:53 pm »
Fitted this
It's for sale if you want it?
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #8813 on: February 10, 2016, 11:40:18 pm »
ed30 R32 rear light mod and soon to be skyline mod.
Why pay to have it done when I can do it myself  :signLOL:
« Last Edit: February 10, 2016, 11:41:52 pm by r5gtt »
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #8814 on: February 11, 2016, 02:21:05 am »
We went in for a brake fluid flush and discovered the need for new axle boots on one side. Went on and replaced both inner and outer boots to the one side.
Still trying to figure out why the auto up and down function for the windows goes out and has to be reset...and the clock needs resetting when this happens. Thought it to be a battery connection issue as I had found the positive clamp loose last week. But after tightening the clamp, finding that the volts are at 12.4v and then 13.9v off the alternator, it happened again. Cannot even guess now as to why and what would be the fix.  :sad1:
Offline Ricky123
« Reply #8815 on: February 11, 2016, 02:28:41 am »
Have a look at the wire from the alternator to the battery. Shouldn't be Over 1v loss from the alternator to battery. I believe that wire was an issue on mk4 golfs so worth a check.
***EDIT**
Think I've miss read your post and you actually mean your getting the lower reading just off the battery and the higher one when the car is running?
« Last Edit: February 11, 2016, 02:30:44 am by Ricky123 »
59 red mk6 GTi 5dr
57 mk5 1.9 TDi match
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #8816 on: February 11, 2016, 02:40:46 am »
Yes...when not running the battery is at 12.4v...and running off the alternator it is 13.9v.
Offline Ricky123
« Reply #8817 on: February 11, 2016, 02:47:04 am »
Thought so.. Me being stupid lol
How often does your clock reset? Is there a pattern to it like every time you turn the car off? I take it that the trip resets at the same time?
Worth checking the fuses for the clocks and Windows. Even if they look fine just swap them out for new ones and see if it stops.
59 red mk6 GTi 5dr
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #8818 on: February 11, 2016, 05:55:38 am »
I have noticed it can reset when driving...I feel a hesitation when I am at a constant cruising speed, but mostly it seems to reset when parked and I have started it up again. I will do as suggested and pop and swap out those fuses. I'll report if a solution is found.
Offline jacobrownoly
« Reply #8819 on: February 11, 2016, 11:16:06 am »
Made 277bhp on revo stage 2+  :jumpmove:
