Author Topic: What did you and your MKV do today?  (Read 2888864 times)
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #10275 on: March 31, 2017, 01:25:44 am »
Fitted aluminium control arms with S3/Passat ball joints. Will get the tracking checked tomorrow. Didn't seem bad on the drive home. :smiley:
Offline slix
  • -Receive: 38
  • Stage 1 ED30 Owner
« Reply #10276 on: March 31, 2017, 08:59:21 pm »
Did an oil change.
Is it me or does the tfsi oil get black really quickly? I don't do mega miles  (4000ish) and when I check the oil a few months after a change it looks black.
The Ford c max on the other hand, the oil is always golden whenever I check it.
Stage "1.5" ED30 [330BHP] Rtech
Offline JamieKirk95
« Reply #10277 on: March 31, 2017, 09:51:49 pm »
So today, I got round to meeting up with @Tfsi_Mike  to fit my cruise control stalk and to enable some features through VCDS.
Got the car connected
Quick scan of the car
Removing the cowling
Mirror used to help locate screws
Airbag off
Wheel off
Control module out
New stalk fitted
And finally fitted with everything back in place
I have also had the following coded;
Auto lock at 10mph
Boot pop via button on key
Remove passenger seatbelt chime (used to go off if you ever put something on it)
Service reminder reset
A massive thanks go out to @Tfsi_Mike for all the help today, even if it took us a bit longer with the bonnet :signLOL: Really nice guy and with a stunning car too :smiley: Really grateful for the help!
Jamie
Offline Shoduchi
  • -Given: 220
  • -Receive: 429
« Reply #10278 on: April 01, 2017, 10:13:16 pm »
fitted or tried to fit both S3 wishbones and super pro ALK last week and snapped a 16mm bolt  :doh:
Fortunately I don't think that ever happened to my cars. Must be a pain to recover the rest of the bolt. :sad1:
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10279 on: April 01, 2017, 10:20:20 pm »
tomorrow I will be replacing the wishbone carrier as I'm not even attempting to recover those siezed bolts. I forgot to put thread lock on which is why it seized and snapped  :doh
« Last Edit: April 02, 2017, 08:36:17 pm by r5gtt »
Offline Eves
  • -Given: 45
« Reply #10280 on: April 02, 2017, 06:35:44 pm »
Fresh clean
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10281 on: April 02, 2017, 08:40:01 pm »
Today I fitted the wishbone carrier, subframe and new bushing, Fitted H&R front and rear roll bars and my rhs S3 wishbone with plenty of grease as the lhs was squeaking everywhere  :doh:
Took me 4.20hr to complete with half cigar breaks. Sad thing was the roll bar nuts were snapped off the brackets so a little fiddly but managed to knock it all together in the end.
Offline Richie-VRS
« Reply #10282 on: April 02, 2017, 08:47:07 pm »
Technically not a mk5 but I fitted a 3" decat and stage 2 bluefin to my Octavia vrs.
Offline neilw
« Reply #10283 on: April 03, 2017, 12:30:24 pm »
Finished my arch and wheel cleanup job on the rear. Pressure washed arches, cleaned up wheels and took off old weigh weight glue. de-tar'd clayed and waxed.
Edition30 #0002 R-Tech Stage2
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #10284 on: April 03, 2017, 07:12:13 pm »
Was yesterday but exterior is now back to standard... end of an era but needs to go now. Got the inside left to do nearer the time of it going.
Offline JamieKirk95
« Reply #10285 on: April 03, 2017, 09:50:57 pm »
Offline lukemk5gti
  • -Given: 28
  • -Receive: 118
« Reply #10286 on: April 04, 2017, 08:22:40 am »
fair play. A lot of people don't tackle this job for fear that they'll crack the spoiler!
Offline r5gtt
  • -Given: 342
  • -Receive: 334
« Reply #10287 on: April 04, 2017, 11:25:21 am »
looks like you got the complete brake light out without breaking it into pieces?. Well done  :happy2:
Offline JamieKirk95
« Reply #10288 on: April 04, 2017, 04:44:14 pm »
[/quote]
Thank you, yeah I was surprised to be fair, we drilled one hole and then a screwdriver in the hole and popped it out! Took 20 minutes or so so could have been a lot worse! Theres some more pictures on my project thread :happy2:
Offline JamieKirk95
« Reply #10289 on: April 04, 2017, 07:47:12 pm »
Noworries thanks, I knew it could be done without snapping the poop out of it and more over can be done without breaking or drilling it too as I've got one from a gti used and undamaged sitting at home waiting biding it's time  :signLOL:
Cheers will check tour thread out  :grin:
[/quote]
Sorry mate I think you missed the bit about me using a drill :scared: Either way it's a doable job if you ever need it doing :happy2:
