Took a punt at one of these Bluetooth module adaptors for music streaming.
Works perfectly with my MFD2, result!
For a few quid you can't go wrong
Connects via the AUX port on the back of MFD2, better yet I kept my stereo AUX connection too, so can play music with AUX wire too if needed
How does this differ to the cheap bluetooth fm transmitters you can get? Wouldn't mind adding bluetooth streaming to my setup
From past experience, those fm transmitters are sh*te. The radio signal/station it taps into has to have a clear signal. If you go into an area where the signal is crap then you'll hear that annoying fuzzy noise. Don't know if they've been improved somehow but didn't wanna go down that route.
This is on the back hidden away so cleaner install. No irritating interference. Powers on and off with stereo. Works for me
thanks, might have to get one then. Where did you buy it from, eBay?
Yep "mfd2 bluetooth"
I read this posting with great interest.
I also have the MFD2 unit and this sounds ideal for adding a bluetooth to my Android phone for streaming.
I'm a complete novice with regards car electrics.
Any chance of a run down of the steps involved?
I can work out where the 12 pin connector plugs in but what do you do with the red and black wires?
Is it best to disconnect the battery before you start?
I take it I will need to know the radio code if the battery gets disconnected?
