What did you and your MKV do today?
Started by ROH ECHT, June 12, 2011, 03:07:21 AM
Previous topic - Next topic
GPem3:16
With all this talk of cleaning.....I ought to get the foamer out.
In other news I swapped the headrests over from front to back...looks sweet tbf.
Sent from my SM-G930F using Tapatalk
GPem3:16
pudding
Wow, getting the foamer out 5 times  :grin:
GPem3:16
Quote from: Pudding on February 20, 2018, 04:11:59 PM
Ooops phone problems. My bad
GPem3:16
GPem3:16
Technical issues :laughingface.
GPem3:16
Wtf is with this sending multiple messages
Nardoblue
Cleaned it and the other toy
ROH ECHT
#11018
Quote from: Nardoblue on February 20, 2018, 11:04:47 PM
Love the GSX1100....1984? Back in 1980 those GSX1100's were the beasts to beat. My 1976 Kawasaki KZ900, with jets/intakes/exhaust/sprockets/lowered/stripped and cafe'd, had trouble with those and the Honda CBX 6 cyl. monsters.
My kz900 started out like...
...and ended up a lot like this 1000 with diff wheels and as much black as I could put on it...
Ads22
#11019
Not much of a whiz with DIY but managed to hardwire dashcam
And then also fitted leather cover to my cloth armrest
Christiank
Manged to finaly get the wirering done for the active TMPS
Also retrofitted heated windshield washer jets, black mk6 golf headliner and pillar trims.
MK5 TDI 2.0 MY2005 - FULL OF RETROFITS:
MK6 dashboard - BCM converted - MK7 cruise control MFSW - PLA 2.0 - 3D instrument cluster - Discover Media 2 - Highline TPMS - 10ch Dynaudio system - KESSY with start button
willni
Advanced a bit with my Passat CC climate control retrofit (Copying @ChristianK ) waiting for the filler to dry to smooth it out fully
Christiank
Quote from: willni on February 25, 2018, 08:31:20 PM
You're getting there mate! :D  :party:
Did you use the repo plast glue or did you end up with a solder iron?
willni
Quote from: Christiank on February 26, 2018, 04:58:43 AM
Tried the epoxy glue first but it didn't work out didn't harden fully (got to about 50% think it was the cold), so I needed up using a soldering iron and two pin nails and joining the two through a weld.
Now I'm just working on the edges to get them nice and straight.
Also did you have to cut two tabs off from the dash just above the two outter circles?
Christiank
Quote from: willni on February 26, 2018, 11:16:51 AM
I didn't cut anything at the dashboard, all were done to the frame :)
