Author Topic: What did you and your MKV do today?  (Read 2981986 times)
dottmary84
« Reply #11415 on: April 11, 2019, 01:39:53 pm »
Loving the front end specially the badge that is awsome !
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #11416 on: April 13, 2019, 04:37:42 pm »
New cam follower and aftermarket turbo heat shield.
Offline kevster996
« Reply #11417 on: April 15, 2019, 01:23:04 pm »
Replaced the shocks and struts all round with good quality boge std parts then replaced springs with eibach 1" lowered all round and new rear bump stops. Much better firm ride on my 4motion, a little lower than stick I think. better than the broken springs that were on the front - one broke in half and the other broke in two places! Also painted up the rear boot badge to gloss black that was badly corroded... Sorry didnt take pics yet.
Next job is new front wings as both gone rusty..
Golf 5 2005, 2.0 TDI 4motion, remapped to 175bhp, lowered on eibach springs, GTI front end, GTI half leather interior
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #11418 on: April 21, 2019, 02:44:24 pm »
Replaced alarm siren so my alarm now works.
Offline OllieL
« Reply #11419 on: April 21, 2019, 02:51:30 pm »
How difficult was this to do, as mine also needs replacing.
Ollie
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #11420 on: April 21, 2019, 03:04:46 pm »
Ollie
Dead easy. Front offside wheel off, about 10 torx screws need undoing so the arch liner can come out and then drill out two metal rivots so you can access the siren. I used two cable ties to re-secure the box that holds the siren to the inner wing. Takes 20 minutes.
Offline kevster996
« Reply #11421 on: April 21, 2019, 04:00:51 pm »
Took the rear boot badge off, sanded it down to get rid of corrosion then primed and painted gloss black. Did the same with the plastic wheel inserts that were black/chrome - now matching the black wheels for a cleaner look...
Offline Octoparrot
  • -Receive: 103
« Reply #11422 on: April 21, 2019, 08:58:33 pm »
Replaced the radiator, intercooler and cam follower.
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #11423 on: April 27, 2019, 02:43:27 pm »
Replaced the black plastic cover that goes over the rear wiper spindle as it was badly faded. Only a minor thing but the rear does look a bit fresher now.
« Reply #11424 on: April 27, 2019, 07:01:20 pm »
New Lambda sensor
Offline absolute
« Reply #11425 on: April 27, 2019, 07:08:23 pm »
Got a part no geezer?
Sent from my SM-G965F using Tapatalk
Edition 30 #1994 now sold. *cries*
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #11426 on: April 27, 2019, 09:12:29 pm »
Boom!  6Q6955435D
Offline Tin Robot
« Reply #11427 on: April 28, 2019, 09:05:15 pm »
Gave her a wash.
Going in tommorow for some bits and pieces - just changed xenon bulbs but need adjustment. Also replacing the under bonnet sound deadening as mine is losing its insides. Apart from that she doesn't need much else done.
Offline Nathan
« Reply #11428 on: May 01, 2019, 09:37:53 pm »
 I changed the diverter valve to a rev G .Absolutely different car .
Old one was slightly torn but no codes
Fitted ram air cai for 'whoosh'
Spark plugs
Then gave it a wash
To do ,oil & filter-cam follower ,refurb some anniversary alloys
Offline Tin Robot
« Reply #11429 on: May 02, 2019, 07:07:18 pm »
Can you stick on any revision? I don't really know the difference between revisions or if I should tackle the job myself. It is running stock so need some guidance.
