Author Topic: What did you and your MKV do today?  (Read 2954257 times)
  • -Receive: 690
« Reply #11685 on: October 18, 2019, 04:04:34 pm »
Mine did 239hp on my local Maha dyno stock with cat-back Milltek, Maha's are usually quite conservative.
230ps, 100% bone stock ED30 on a Sun Dyno.
Obviously there will be a bit of variance over winter, but I'm a bit dubious of standard engines measuring significantly more than the factory quoted power.
Offline DaveyBoyWonder
« Reply #11686 on: October 21, 2019, 01:22:09 am »
Pads done the other week but blew up my 21mm socket so bought a new one and did the discs today. Noticed a split in the offside CV boot so that needs doing next.
Been thinking about replacing the Golf again and weirdly gone full circle and decided we might replace it with................ an ED30  :grin:
Offline ljc19630
« Reply #11687 on: October 21, 2019, 07:40:22 am »
I used a tool off ebay, tubing with metal connectors on either end, one went onto the bottle of oil, the other screwing into the drain/fill hole in the gearbox.
When I finished filling it still I managed to cover my hands, arms and floor in oil.
Fluid coming out was darker then that i put in. It's been 20k miles and 18 months since the last change and the gearchange is noticeably smoother now. VW say the service interval is 40k miles, hmm.
I’ve bought one of these for my next DSG service Saw one used on Deutsch Auto Parts (YouTube) and makes the job simple
Offline ljc19630
« Reply #11688 on: October 21, 2019, 10:38:18 am »
Weekend work consisted of the continuation of going over the WHOLE car using Dr.Colorchip stone chip remover. Brilliant stuff, but takes a while to complete asyou need to be patient. Also fixed sidelight fault, as one of the pins on the loom connector had bent, hence LED sidelight was out
Offline Mark_DF05
« Reply #11689 on: October 21, 2019, 12:41:30 pm »
Had 2 new Goodyear ASY5's put on the front and gave it a quick wash.
@ljc19630 looking clean! what sidelight bulbs are they?
Offline Matimcfet
« Reply #11690 on: October 21, 2019, 12:48:39 pm »
Did you manage to get the light out without taking bumper off?
Offline ljc19630
« Reply #11691 on: October 21, 2019, 12:55:09 pm »
Labor of love, as spent many hours compounding & polishing etc (part time detailer is me) and the Dr.Colorchip is brill too!!! Stll have the N/S panels and roof to do :laugh:
Headlights are retrofitted Xenons, but i had them made up by EM Tuning (an old pal from RS4 days) hence he fitted RS4 running gear and super bright LED sidelights. Also upgraded the spots to LEDs - AMAZING nighttime brightness even just with the spots on :-)
Offline Matimcfet
« Reply #11692 on: October 21, 2019, 12:58:30 pm »
I have retrofitted xenons with an indicator issue and its doing my nut in, maybe worth checking the wires if thats what happened to yours?
Offline terrier
  • My Ride: GTI now gone
« Reply #11693 on: October 21, 2019, 04:34:47 pm »
wheel swap from BBS to ATS.  Was going to swap for the winter in any case but a kerb incident happened :surprised: Also bought new centre caps for the BBS (aliexpress copies perfect fit and price) Did the swap at work so got paid to do it :signLOL:
  • -Receive: 690
« Reply #11694 on: October 22, 2019, 02:24:50 pm »
Mine is gagging for some Dr Colour Chip action.  Do you just splodge it onto the chips, squeegee it in and then wipe off?  Seems too easy and too good to be true!
I couldn't find plain black on their site, only pearls and metallics.
  • -Receive: 690
« Reply #11695 on: October 23, 2019, 03:39:49 pm »
Another year, another MOT pass but got an advisory on a dead third brake light.  Something I think we all have to do at some point!
Offline GVK
  • -Receive: 68
    • GVKmotorsport
« Reply #11696 on: October 23, 2019, 05:57:58 pm »
Mine's not working either, had the car 2 years been a brand new one in the door pocket.
Must get round to fitting it....
  • -Receive: 690
« Reply #11697 on: October 24, 2019, 12:16:51 pm »
Apart from having to break the old one out, it doesn't look like it's too bad a job.  At least when the first one is busted out, future replacements will be a lot easier!
  • -Receive: 690
« Reply #11698 on: October 26, 2019, 11:16:44 am »
Well that was hilariously easy  :grin:  Punch a hole into the red bit with a screwdriver and then hack away!  Literally takes 2 minutes to rip it all out.
The only awkward bit is seating the new grommet into the spoiler as it's quite deeply recessed.  I'm not sure if folk bother doing that but I did, just in case it prevents water from getting into the car.
Skill level - 1 spanner  :happy2:
Tools required - Hammer, screwdriver, long nose pliers and if you have them, a right angle pick to help you pull the old grommet out.
Offline Juliand
« Reply #11699 on: October 26, 2019, 11:22:57 am »
I thought that someone on here mentioned recently that 3rd brake light wasn't an MOT Fail item..... So how can it be an advisory? Puzzled??
