Author Topic: What did you and your MKV do today?  (Read 2982488 times)
Offline dubburke
« Reply #11820 on: March 27, 2020, 06:13:52 am »
got rid of the horrible cloudy headlights by wet sanding them with 800, 2000, 3000 grit sandpaper then sealed them.
I can now see in the dark :signLOL:
Offline titchy
« Reply #11821 on: March 27, 2020, 11:12:33 am »
thanks for info
Offline terrier
  • My Ride: GTI now gone
« Reply #11822 on: March 27, 2020, 02:33:22 pm »
fitted new rear red trw calipers. carriers, textar pads HEL lines and EBC grooved discs   :happy2:
Offline Paul.f
« Reply #11823 on: March 28, 2020, 10:08:29 pm »
Fitted a Milltek non resonated cat back exhaust.
Offline RobC
  • -Receive: 20
« Reply #11824 on: March 28, 2020, 10:13:48 pm »
Gave the car a deep clean
Offline Wakkk
« Reply #11825 on: March 30, 2020, 11:03:13 am »
Gave them both a good deep clean (picture for results) found £5.46 in change once I took the seats out!
https://www.flickr.com/photos/187635591@N08/49715824046/in/dateposted-public/#
Offline Cosmos
  • 376bhp 423lbs torque
  • My Ride: Golf Gti Edition 30
« Reply #11826 on: March 30, 2020, 08:59:52 pm »
Had my eddy booked in at a vw specialist  today for over a month for its timing belt kit,aux belt,water pump and oil change service.
Had done 12396 miles and 5 years since its last belt change and 2331 miles and 1 year since its last oil change.The car is on 36k miles. Good to see a fresh aux belt on it and golden oil on the dipstick
Offline J66hhr
« Reply #11827 on: March 30, 2020, 09:08:24 pm »
Due soon how much am I looking roughly
Offline Cosmos
« Reply #11828 on: March 30, 2020, 09:15:07 pm »
I was £450 for the lot.Also recently bought a set of pbs pads to go in the ttrs calipers,will get them fitted soon.
Offline GVK
  • -Receive: 69
    • GVKmotorsport
« Reply #11829 on: March 31, 2020, 10:42:13 pm »
Gave the Ed30 a bath.
#snowfoam by GVKmotorsport, on Flickr
Offline Callumgti30
« Reply #11830 on: April 14, 2020, 04:13:31 pm »
Gave her a wee polish.
Sent from my POT-LX1 using Tapatalk
« Last Edit: April 14, 2020, 05:07:04 pm by Callumgti30 »
06 mk5 Gt TDI. Daily driver.
08 mk5 Gti Edition 30 no2301,
Offline RobC
  • -Receive: 20
« Reply #11831 on: April 14, 2020, 04:19:44 pm »
Did a Mk6 dash conversion over the weekend...
Just need a sunlight sensor and clocks coded now!
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #11832 on: April 14, 2020, 04:50:19 pm »
How much hassle was this?
Offline RobC
  • -Receive: 20
« Reply #11833 on: April 14, 2020, 04:54:27 pm »
Months of research, making multiple new contacts to get info, plenty of help from others, a few wiring diagrams, couple of adapter looms for what was essentially a couple of hours work!
Really enjoyed it though and the time spent preparing beforehand made it an easy install. The dash itself just bolts straight in, there are just a few bits you need to consider around that.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #11834 on: April 15, 2020, 03:03:06 am »
Today I did the thing...and got the Quantum HFP A35HV 265 L/hr pump installed into the oem basket. It was as easy as I thought it would be.
A few tips I would recommend are;
1) place the new smaller o-ring onto the lip down in the basket rather than inside the bottom opening of the pump just before inserting the new pump back into the basket. I saw this tip in this vid and it worked very well.
2) remove the mesh screen first thing and later, use the opening on the screen to align the positioning of the new pump when dropping into the basket. Check the new pump's position when you have felt it snap onto the smaller o-ring( ↑ as shown in the vid)...then the pump can be rotated so the small port on its bottom is aligned to receive the mesh screen upon reattachment.
3) I used a heat gun on low to warm both ends of the new tubing, one end at a time of course, so they would slide on easier. I know this may sound dangerous but going to say it anyway, when warming one end prior to pushing it into place...place your thumb near the end of the tubing so to know you are not overheating the tubing. If you can stand the heat on your thumb, you are not overheating it. When the tubing is warm, it will slide on much easier. A Quantum tech gave me this tip and I am happy he did because when checking the tightness prior to heating, I could see how one may end up breaking one of the ports the tube connects to.
DW - left.....Quantum - right
« Last Edit: April 15, 2020, 03:06:32 am by ROH ECHT »
