Author Topic: What did you and your MKV do today?  (Read 2971910 times)
Offline MKMike
« Reply #12030 on: March 12, 2021, 07:26:25 pm »
Hi boys,
Does this start up sound ok to you? To my untrained ear it's a bit "coughy and laggy" suggesting an old battery maybe?
https://streamable.com/pn8trd
What we supposed to be listening to? Can only hear the ping of the alarm lol.
Sorry one without the seatbelt noise   :laugh:
https://streamable.com/0cnrl9
  • -Receive: 690
« Reply #12031 on: March 13, 2021, 03:35:39 pm »
I've been getting some loud sucking noises in boost lately, so decided to replace the turbo intake hose - https://www.akstuning.co.uk/shop/home/1467-genuine-air-intake-pipe-06f129627h.html
Glad I did as the old one was all brittle and crunchy sounding when squished, plus the oil build up on the jubliee clamp is an obvious sign of leaking.
A previous owner has obviously fitted an intake kit at some point (I would never use jubliees as they're crap) so fitted the proper OEM spring clamp to apply the correct tension on the pipe.
All quiet again now, and probably better fuel trims too  :smiley:
Offline DBXdarkangel
  • -Given: 18
« Reply #12032 on: March 15, 2021, 12:07:33 pm »
Fitted some LED indicators and some genuine gti floor mats.
Offline Jons1001
« Reply #12033 on: March 15, 2021, 12:15:24 pm »
looks very smart. Where did you get the mats?
  • -Given: 18
« Reply #12034 on: March 15, 2021, 01:20:45 pm »
T L DARBY VW dealer via ebay
l
Offline MKMike
« Reply #12035 on: March 16, 2021, 05:23:09 pm »
went in for a health check, since I bought it a couple of weeks ago...
-Adjusted steering sensitivity - now doesn't feel like you're steering a tank
-Drivers headlamp broken, and cable tied...
-Hand Brake Travel High
- *most concerned, Oil Leak from gear box. Starting to drip (guy said, it looks like they spray painted the box  to cover the leak)
-Intake pipe broken and insecure
-NSR Road spring broken (they said it was shilted in)
-Head light level sensor arm missing
the above are not taking into account problems I found with passenger driver side door not opening from the outside, the boot lid not snapping back and the car is slow to start although the battery is measured at 68% health.
Not amused with the dealership I bought the car from, nor the MOT centre they used the door being unable to unlock is a fail.
Offline fakie1977
« Reply #12036 on: March 20, 2021, 05:36:13 pm »
Finally got around to installing the replacement DSG gear knob and surround I bought off the forum (thanks Louie)
My old gear knob and gaiter itself wasn’t too bad (some scuffs seen on left) but the surround was starting to look tired.
Looking all new and shiny now.
Any interest in my old one give me a shout.
Offline GPem3:16
« Reply #12037 on: March 20, 2021, 05:39:03 pm »
Purchased....2 x new wings La7w.
Fed up of looking at the bubbles
Sent from my SM-A715F using Tapatalk
Offline Jb55
« Reply #12038 on: March 20, 2021, 05:56:37 pm »
@fakie1977 hi mate I’m interested in the gear knob and surround, have pm’ed you but not sure if it sent or not.
Offline fakie1977
« Reply #12039 on: March 20, 2021, 06:23:47 pm »
Responded back. Thanks
Offline terrier
  • My Ride: GTI now gone
« Reply #12040 on: March 20, 2021, 06:46:39 pm »
repaired a 10 yr old chip on the hatch edge.
Offline Sean_ED30
« Reply #12041 on: March 21, 2021, 12:03:59 pm »
Got hold of some Passat hubs. Removed the old bearings and gave them a clean. Got some new SKF wheel bearings on order.
Offline Stupots
  • -Given: 18
« Reply #12042 on: March 24, 2021, 03:33:17 pm »
Picked up a genuine Ed30 alloy locally for a spare. Will get it refurbed the same place as my others (Which are still in my loft  :grin:) www.lepsons.com in Gillingham in a Light Anthracite finish.
« Last Edit: March 24, 2021, 03:36:09 pm by Stupots »
2006 VW Golf Mk5 Sport TDI 4Motion (140 BKD)
Offline probedb
« Reply #12043 on: March 25, 2021, 08:59:04 am »
Today I'll mostly be clipping off the nearside rear brake splash guard because it's too much work to replace it right now and it produces the loudest sound known to man when it rattles. Also need to figure out why my rear wiper has stopped working, probably the same reason the rear demist and boot switch have stopped working as well.
Offline brian_badonde
« Reply #12044 on: March 25, 2021, 01:17:34 pm »
I have the exact same issue with electrical stuff on the boot hatch. I'm 99% sure it's down to the wiring fraying underneath the rubber outer at the boot lid hinge. Not sure if there's a plug and play replacement or whether you have to repair individual wires, will post back here once I've figured it out.
Sent from my SM-G960U using Tapatalk
