Author Topic: What did you and your MKV do today?  (Read 2842410 times)
Offline Sebas_theFish
« Reply #12165 on: July 21, 2021, 09:53:44 am »
New wiper linkage and new steering wheel.
Sent from my Samsung Smart Fridge
Offline shail
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99663.msg979899.html#msg979899
« Reply #12166 on: July 21, 2021, 04:27:16 pm »
BADLY kerbed the front passenger side alloy  :sad1:
Ouch.  I did my driver's side last week, so feel your pain!
Offline Stupots
  • -Given: 18
« Reply #12167 on: July 21, 2021, 08:38:52 pm »
Got in my car this morning and realised I'd reached a milestone 200000 miles!
Some rust creeping in on the front of the lower rear aches/rear of sills, but still going strong.
« Last Edit: July 22, 2021, 03:45:54 pm by Stupots »
2006 VW Golf Mk5 Sport TDI 4Motion (140 BKD)
Offline GVK
  • -Receive: 68
    • GVKmotorsport
« Reply #12168 on: July 22, 2021, 01:05:43 am »
GOT caught speeding 61 in a 50 in Stoke.
nip by GVKmotorsport, on Flickr
Good pic of car though eh????
Offline mjmallia
  • -Receive: 57
« Reply #12169 on: July 22, 2021, 09:28:02 am »
Had a small vacuum leak I was seeing on my digital boost gauge that was getting worse.  I spent ages trying to find it as all connections were dry with reasonably new seals.
I finally discovered the boost sensor for the gauge was bleeding air, so put my old mechanical one back on and solved  :confused:!
That was a simple fix but a pain to locate.
Mike
South Coast
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #12170 on: July 22, 2021, 01:36:31 pm »
Fitted a sunstrip on the windscreen. I had one previously but I managed to rip it when I was scraping ice off the windscreen in winter.
Fitted o ring in intercooler hose connector that I'd lost when fitting the s3 intercooler.
Offline Stupots
  • -Given: 18
« Reply #12171 on: July 22, 2021, 03:24:49 pm »
Replaced my battery
I've been having battery issues since the start of lockdown. As I was able to work from home it didn't bother me too much and I picked up a new battery charger. The car would be flat if left for a few weeks without driving, so I assumed one of the retrofits is causing a slow battery drain. More recently I've been driving the car every 3 or 4 days, but it still went flat, so that got me thinking my 5 year old battery may be unhealthy.
I did a bit of research on which one to get, it appears that AGM batteries can be fitted, but if your car wasn't fitted with one from factory the charge characteristics may cause issues, as AMG batteries have higher voltage peaks (So your car would require a Battery Management System or Intelligent Battery Sensor to manager them correctly) as well as requiring charging 0.3V above conventional flooded batteries. I then came across EFB, which are Enhanced Flooded Batteries and are a halfway house between Flooded and AGM batteries and can be fitted to cars that came with either from factory. I guess you'd use EFB in your start/stop car if you couldn't stretch to the price of an AGM. For people with a regular battery from factory and EFB makes a nice upgrade; better charge acceptance and typically double the duty cycle and only about 30% more expensive.
Anyhoo, I went for a Varta N70 (an 096 type for our Mk5 cars) and I'll keep you posted how it performs. It was £90 with an eBay 20% off coupon, which is the cheapest I could find and has a 4 year warranty.
I also discovered during my research that Bosch and Varta have been the same batteries for the last 7 years, the only difference being the labels they stick on them. The Varta was cheaper than the Bosch part.
Stu
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=nfjtcjppkabue0bsfthv0bu5pj&/topic,19740.0.html
« Reply #12172 on: July 22, 2021, 03:48:04 pm »
The varta e44 is a bit cheaper and a good choice if anyone is searching.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #12173 on: July 22, 2021, 11:29:07 pm »
Re-installed a new catalytic converter to my turbo-back. Just all part of returning it to a more grown state.
This is it and is the same as the one I removed some 7 to 8 yrs ago from my Techtonics Tuning Turbo-back;
Offline MattC
« Reply #12174 on: July 25, 2021, 07:44:23 pm »
Changed oil with Castrol Edge 5W-30 LL and OEM Oil Filter after 1 year and 2k miles (due to covid, working from home and driving on the weekends) :happy2:
« Last Edit: July 25, 2021, 07:46:42 pm by MattC »
Offline probedb
« Reply #12175 on: July 26, 2021, 12:11:52 pm »
Yesterday finally replaced the rear nearside boot loom and got my wiper and boot latch working again. Just trying to see if I can get the high level connector out without cutting wires instead, seems doable to me.
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #12176 on: July 26, 2021, 02:04:02 pm »
air con regassed and anti-bacterial stuff spraying into the system.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
« Reply #12177 on: July 27, 2021, 08:14:48 pm »
Just placed an order for APR's new coils. Finally going to put the stock OEM coils away. Not doing so for any reason other than to see if this all increases fuel mileage and drops/reduces the +7.8% LTFT while still allowing it to run as good as it's been running.
I already use a 5k Ohm spark plug (PFR7B) with a 0.7mm gap. And that gap is sometimes reduced to run well with the OE coils...depends on where I have the peak boost.
These APR coils should allow me to order plugs with the 0.8mm gap (BKR7EIX) with no need to run any plugs with a 0.7mm gap or less. A larger gap should improve fuel burning efficiency. They are less expensive than genuine R8 coils...I like that. I only hope they are durable...as I have never needed to replace the stock genuine coils.
Offline Rampage
« Reply #12178 on: July 28, 2021, 02:53:38 am »
Ohhhhhh just spotted your ‘Joying’? stereo?
Tell us all about it... Do you rate them? CarPlay work ok? Any battery drain issues? Etc
Cheers  :happy2:
Offline MKMike
« Reply #12179 on: July 30, 2021, 11:02:53 am »
it's been pissing down and I have a leak in the seal so water is pouring onto the pedals. Anyone know the part number for the black seal around the windscreen that goes to the front bonnet
