Author Topic: What did you and your MKV do today?  (Read 2969731 times)
Offline Sebas_theFish
« Reply #12465 on: August 08, 2022, 01:21:43 am »
Installed the ECS stage 1 rear stress bar and a set of DLI-TEKNIK upper engine mounts.
Sent from my Samsung Smart Fridge
  • -Receive: 690
« Reply #12466 on: August 08, 2022, 02:38:58 pm »
Good stuff. I've got a TyrolSport Stage 2 equivalent stress bar in the loft somewhere. Looks pretty much identical to the ECS one.
What do you think of the DLI mounts?  Quite an interesting design. Noisy by all accounts (gearbox one especially), but not as harsh as poly.
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #12467 on: August 08, 2022, 06:12:14 pm »
I like their stage 2 kit and that both stages 1 and 2 just clamp on (and bolt for stage 2) rather than drilling holes for inserts...but I do fold the seats down for additional space from time to time. It appears stage 1 would be sufficient though for a mostly; daily driver. Your thoughts since the addition of the stage 1 stress bar?
« Last Edit: August 08, 2022, 06:15:43 pm by ROH ECHT »
Offline colesey
  • -Receive: 89
« Reply #12468 on: August 08, 2022, 06:18:47 pm »
Washed the bird crap off after my holiday and insured it.
« Reply #12469 on: August 09, 2022, 12:24:23 am »
It's great! I specifically bought this kit because I didn't need to drill anything and it minimises space lost in the hatch, I fold the seats down to transport stuff occasionally too. It's only 2 nuts to remove the bar if I ever need more apace so no hassle.
« Reply #12470 on: August 09, 2022, 12:28:06 am »
I did consider the Tyrolsport one too but couldn't see how they justified the price for the same design. The DLI mounts are absolutely fantastic. No vibration or harshness they just enhance the mechanical sounds of the engine, this seems to be the advantage of the spring vs poly. I would absolutely buy another set.
Offline mjmallia
  • -Receive: 57
« Reply #12471 on: August 09, 2022, 03:46:03 pm »
After looking at getting a braided line for the clutch, I stumbled across the removal of the clutch delay valve in the bleeder block......so decided to tackle that. Quite an easy and quick job, then bleed the clutch again
My info came from here
https://www.vwroc.com/forums/topic/12185-tutorial-clutch-delay-valve-removal-manual-cars/
Mine was also black, where the majority are yellow. Not had a chance to drive the car yet
UPDATE Just drove the car and it is a lot smoother and instant if that makes sense. I like it  :happy2:
« Last Edit: August 09, 2022, 06:06:49 pm by mjmallia »
Mike
South Coast
Offline colesey
  • -Receive: 89
« Reply #12472 on: August 09, 2022, 06:16:02 pm »
@mjmallia - don’t think twice about adding the braided hose as it makes a bigger difference than the bleeder block restrictor. Clutch action becomes quicker / lighter / more accurate.
  • -Receive: 690
« Reply #12473 on: August 10, 2022, 02:35:52 pm »
The ECS one wasn't around when I got the Tyrol one, but I bet it's better made.  Tyrol had to send me another one due to quality issues.
Good to know about the DLI mounts  :happy2:  Yours is an R32 though, so smoother in the first place!
  • -Receive: 690
« Reply #12474 on: August 10, 2022, 02:39:51 pm »
I can second that. The biggest improvement for me is the much more consistent shifts. They were fine from cold on the standard setup, but after 45mins-hour, the shifts started getting progressively worse, which I can only put down to the rubber section of the hose expanding.
It just makes a clutch feel like it should.  The standard arrangements make it feel vague and woolly.
Offline GilesWoodward59
« Reply #12475 on: August 10, 2022, 08:23:02 pm »
Annual wash & interior clean  undertaken ahead of photos for agreed value insurance
Edition 30 - No. 1233
Offline jacksosi
« Reply #12476 on: August 11, 2022, 01:56:00 pm »
9th MOT pass in a row, she's a good'n  :congrats:
Black MkV Gti (Nov 2008), no modifications
Offline ttelracs
« Reply #12477 on: August 20, 2022, 10:22:48 pm »
I did this, drilling out the restrictor on the fuel line and since I have the banjo bolt I just had to remove the rubber hose to access it.
Why? Because when I used to accelerate hard it would keep cutting out like fuel cuts were happening.   Over the last 9 months I had changed the in-tank fuel pump, the fuel pump, three oil changes, spark plugs, checked the coils, the cam follower and hpfp and I was still getting cut outs which felt like misfires.
But this little mod worked, thanks @ROH ECHT as I found on an american Golf forum.  I drilled it out to 4mm but now it pulls without any hesitation, spluttering, cut outs or misfiring, no matter which gear in. Unsure if any gain to be had by going 5mm, so I think I'll leave it as it is. Thanks again.
« Last Edit: August 21, 2022, 07:25:48 pm by ttelracs »
  • -Receive: 690
« Reply #12478 on: August 23, 2022, 09:13:03 am »
Is it remapped?  I can't help but think there is something else at play here otherwise VW would ship the pumps with the fitting already drilled to 5mm.
Offline terrier
  • My Ride: GTI now gone
clocks display fade fading
« Reply #12479 on: August 24, 2022, 03:21:52 pm »
LCD display fading has been getting worse Seems to be the hot weather :thinking: Anyway I bought a replacement display from HK
Had it fitted within 1/2 hr  straighforward as long as you dont scratch or snap any fastenings :happy2:
« Last Edit: August 24, 2022, 07:52:24 pm by terrier »
