Author Topic: What did you and your MKV do today?  (Read 2968041 times)
Offline stevw1
« Reply #12630 on: April 17, 2023, 12:23:08 pm »
Went to Elsecar at the Races
Offline GilesWoodward59
« Reply #12631 on: April 19, 2023, 11:12:57 pm »
Managed to find a lay-by!
Edition 30 - No. 1233
Offline Birchy
« Reply #12632 on: April 25, 2023, 03:44:24 pm »
Gearbox out and stripped and bolts drilled out ready for the quaife…lots of parts arriving this week so hoping it’ll all be done and fitted by the weekend! Haven’t done one of these before so pretty interesting taking it all apart!
Offline Grevling89
« Reply #12633 on: April 29, 2023, 09:21:38 pm »
And how many times exactly did you drive back and forth on the lay-by until it rolled over??  :grin:
2007 MK V - Pearl Black - 5 door - Happily stock
Offline shail
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,99663.msg979899.html#msg979899
« Reply #12634 on: April 29, 2023, 09:53:01 pm »
I replaced both radiator fans today.  Not to difficult to do, but did manage to snap one bolt, which is now stuck.  I don't like bodges, but I'll have to think of a way of securing the shroud to the rad in the top right corner.
Online fakie1977
« Reply #12635 on: May 08, 2023, 08:03:19 pm »
Finished today but took several weeks to get parts. What started off as a simple job replacing headlight bulb as I had warning in dash ended up to be much bigger job. Turns out my igniter for my NS xenon blew. Could not get easy access so ended up taking apart front end to get headlight out. Figured I might as well swap over all the bulbs whilst it’s out. So took both headlights out.
The replacement igniter that I bought was aftermarket (OEM on left and aftermarket on right) and no matter how I tried I couldn’t get it to fit. So sent that back and in end bought OEM.
Whilst the bumper was off notice washer fluid leaking - turns out it was a small o-ring on the connector from the washer bottle to the headlight washers. Didn’t know size of o-ring so just bought replacement connector and fitted that. No leaks and all put back together. All headlights now work. It’s a good job it’s not my daily!!!
« Reply #12636 on: May 09, 2023, 11:33:16 am »
I was on 999998 miles so I used google maps to find a lay-by 2 miles away :signLOL: should have given the dash a dust before I took the photo!
Offline terrier
  • My Ride: GTI now gone
« Reply #12637 on: May 12, 2023, 04:58:19 pm »
Ordered a new set of B14s  The ones i have fitted at present were taken off my GTI before i sold it
  Were on the gti for around 4 years and 3 years on the sootchucker  Thought about returning to standard until i found the B14s for £800+ :happy2:
Offline antonis42
« Reply #12638 on: May 14, 2023, 05:15:04 pm »
road trip to ancient olympia rest stop to stretch and refresh
Offline Marticus
« Reply #12639 on: May 21, 2023, 08:34:05 pm »
Noise pipe removal:
Offline Birchy
« Reply #12640 on: May 23, 2023, 10:10:36 pm »
Since fitting the LSD my standard console bushes have decided to pretty much disintegrate. No idea how long they’ve been on for (I’m assuming they’ve been changed at some point.
I tried to free off the dreaded bolts…near side…all came undone with some heat and persuasion. Off side…not so much lol.
Tonight I finished off tackling the friendlier side. Wishbone removed and bushes taken off/pressed out. Wishbone rubbed back and painted with satin black tough paint. Poly bushes fitted and arm refitted with new bolts…making sure to use anti seize!
I’ve got a brand new second hand subframe bracket to fit to the off side so will probably tackle that tomorrow as well as getting the wishbone looking a bit better to match the near side.
As it stands I’ve got a snapped bolt and the other one is going the same way…huge, huge joy! Lol
Offline deltawing
« Reply #12641 on: May 26, 2023, 06:35:18 pm »
Headlights restored using a autoglym kit, came up crystal clear
Offline Dogg1210
« Reply #12642 on: May 30, 2023, 02:19:05 pm »
Little clean
Offline skkane
« Reply #12643 on: June 02, 2023, 06:43:39 pm »
So, I was fixing a rear license plate light then this happened  :signLOL:
« Last Edit: June 02, 2023, 06:45:26 pm by skkane »
2007 ED30
Offline bobby_fodge
  • -Given: 22
  • -Receive: 38
« Reply #12644 on: June 05, 2023, 09:31:17 am »
Bought a mk5 R32. Advert for my GTI coming soon.
