Author Topic: What did you and your MKV do today?  (Read 2960534 times)
Offline ROH ECHT
  • -Given: 113
  • -Receive: 149
  • K04 PLAY....ZOOM DIS!
« Reply #7890 on: March 03, 2015, 02:21:45 am »
Changed my cam follower. There wasn't much wear but having only got the car in December and not knowing if it had been done or not it was worth doing.
It wasn't lose to pull out, though. It was stuck and I had to use pliers to get it out with a bit of a tug I have to say. Is this a problem? Don't know if it's just placebo but the engine sounds like it's running better now...
I always install my new followers with a coating of graphite engine assembly lube inside and out. I show the lube near the beginning of my diy vid:
I have changed my follower about 5 or 6 times due to my hpfp upgrade, and I think my follower has once been stubborn when removing. The engine assy. lube I use now has remedied it ever happening again.
« Last Edit: March 03, 2015, 02:27:47 am by ROH ECHT »
Offline Dave7692
« Reply #7891 on: March 03, 2015, 09:00:53 am »
Sold it  :sad1:
On a plus side though I pick up my Scirocco on Saturday   :driver:
Offline sgour
« Reply #7892 on: March 03, 2015, 11:17:13 am »
Bought a REVO intake  :smiley:
Offline shortdan14
« Reply #7893 on: March 03, 2015, 05:26:54 pm »
Sixth gear clutch slip....
After much much internal debate, took a plunge and have ordered a southbend stage 2 daily from upsmotorsport.
Awaiting delivery...
Offline K9
  • VW LifeStyle
« Reply #7894 on: March 03, 2015, 05:36:16 pm »
not to my car but i bought or ordered 36 application pads and 30 microfiber cleaning towels for the summer :)
Offline GTiBlues
  • Mr Blues
    • Bookface
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,75444.0.html
« Reply #7895 on: March 03, 2015, 06:14:59 pm »
Bought and fitted the Rev R PCV. Also bought a n/s door mirror as the glass just popped off this morning, £36 later fitted it. Also ordered in Millers Nanodrive for the cars 6000mi service
Offline wesrev87
« Reply #7896 on: March 03, 2015, 06:18:36 pm »
Can I ask where you got the mirror from? My drivers side glass wobbles at speed, so I don't think it will be long before it drops out :signLOL:
Offline GTiBlues
  • Mr Blues
    • Bookface
« Reply #7897 on: March 03, 2015, 06:21:12 pm »
TPS dude, usually got them in stock. Just go to your nearest retailer
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #7898 on: March 03, 2015, 06:46:11 pm »
Get a bit of silcone or no more nails on it before you lose it and save yourself a few quid  :happy2:
Offline wesrev87
« Reply #7899 on: March 03, 2015, 06:54:26 pm »
I'll definitely give it a try, thanks  :happy2:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #7900 on: March 03, 2015, 06:58:05 pm »
It's a common enough problem, did this to mine two years ago and still going strong, just don't use too much, or you block the heated mirror element  :happy2:
« Last Edit: March 03, 2015, 06:59:49 pm by fab5freddy »
Offline Jarre
« Reply #7901 on: March 04, 2015, 01:29:55 pm »
This could be a really stupid question, this is my cam follower I removed, is it worth keeping and using again for a few thousand miles once my other one has worn through or just get rid?
Candy White ED30 :)
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #7902 on: March 04, 2015, 02:04:00 pm »
Personally. Get rid of it
« Reply #7903 on: March 04, 2015, 02:07:14 pm »
Looks ok, but as its out you might as well stick a new one in
Offline Jarre
« Reply #7904 on: March 04, 2015, 02:24:25 pm »
I've already put a new one in, it's just whether I keep that as a spare or just chuck it :)
Candy White ED30 :)
