April 25, 2025, 03:50:10 pm
All Things Mk5
Mk5 General Area
Edition 30 owners - how much hissing?
Topic: Edition 30 owners - how much hissing? (Read 3036 times)
_Nathan_
Always Involved
-Given: 3
-Receive: 1
June 16, 2011, 08:19:42 pm »
As said really, if you drive along with the window down how much hissing can you hear when you depress the accelerator?
E90 M3, E46 CSL Race car
Tfsi_Mike
Just look at my post count
-Given: 241
-Receive: 309
Go Large or Go Home
My Ride:
Re: Edition 30 owners - how much hissing?
Reply #1 on:
June 16, 2011, 08:25:26 pm »
Standard - next to none
Standard with Forge spacer - lots
ITG inlet with forge spacer - lots and lots!
Tfsi_Mike
-Given: 241
-Receive: 309
Go Large or Go Home
My Ride:
Reply #2 on:
June 16, 2011, 08:28:02 pm »
Also I found some time ago a vacuum hose split to my DV and that hissed alot...
HTH
_Nathan_
Always Involved
-Given: 3
-Receive: 1
Reply #3 on:
June 16, 2011, 08:35:44 pm »
Very useful thanks
bacillus
-Given: 4
-Receive: 451
Reply #4 on:
June 16, 2011, 08:39:15 pm »
Do you have one of these under your bonnet?
_Nathan_
Always Involved
-Given: 3
-Receive: 1
Reply #5 on:
June 16, 2011, 08:51:29 pm »
You've made me scared to look now ;)
Very pronounced hissing.
Tfsi_Mike
-Given: 241
-Receive: 309
Go Large or Go Home
My Ride:
Reply #6 on:
June 16, 2011, 09:15:54 pm »
Does it feel like there's a loss of boost or performance at all?
Tfsi_Mike
-Given: 241
-Receive: 309
Go Large or Go Home
My Ride:
Reply #7 on:
June 16, 2011, 09:33:24 pm »
Goes to photobucket to dig out pic*
The soft rubber ones the same diameter as the tubes used for window washers.
Tfsi_Mike
-Given: 241
-Receive: 309
Go Large or Go Home
My Ride:
Reply #8 on:
June 16, 2011, 09:46:54 pm »
Split diaphragm in the DV perhaps?
_Nathan_
Always Involved
-Given: 3
-Receive: 1
Reply #9 on:
June 16, 2011, 09:53:11 pm »
Have already ordered another DV just in case, how common is it for Rev D valves to fail?
Thanks for pics, will go and have a look see.
Tfsi_Mike
-Given: 241
-Receive: 309
Go Large or Go Home
My Ride:
Reply #10 on:
June 16, 2011, 09:54:38 pm »
The hoses in/out of the sensor in the top right of the pic too
heavyd
-Given: 29
-Receive: 29
Reply #11 on:
June 17, 2011, 12:44:46 pm »
Did the System too Rich at Idle error code come back on whilst on Revo stock code? It sometimes would come on VCDS 2 days after the fault had actually occured when I checked after converting the Km to Miles.
Hedge
-Given: 484
-Receive: 304
Reply #12 on:
June 17, 2011, 01:38:28 pm »
Do you wan me to drive and confirm Nathan?
Hurdy
-Given: 52
-Receive: 137
Reply #13 on:
June 17, 2011, 02:00:51 pm »
I though rev d diverter was the piston type!
It wouldn't fail if it was a rev D DV
I haven't heard of any revD DV's going.
Hedge
-Given: 484
-Receive: 304
Reply #14 on:
June 17, 2011, 02:20:17 pm »
I seem to remember Forge suggesting rev D's had failed.
Why not come down to JKM and stick it on the Dyno. At least you would have some idea if there is a problem or not.
All Things Mk5
Mk5 General Area
Jump to:
=> Mk5 General Area
