Author Topic: What Are Your Revo Settings?  (Read 36684 times)
Offline RobB
Re: What Are You're Revo Settings?
« Reply #105 on: April 29, 2011, 11:09:50 pm »
Possibly a dumb question, but haven't found it answered elsewhere.  Just got an Ed30 & Revo'd it last week.  Looking through this forum, everyone has F9 on a standard fuel pump, "because it can't handle any more", but the SPS manual says 9 is "performance" and 0 is "stock".  Seems the wrong way round?!  Please can someone explain why F9 is correct? Thanks in advance. Rob.
Quote
Fuel Adjustment:
Range 0 Stock Air-Fuel Ratio (AFR)
Range 9 Performance Air-Fuel Ratio (AFR)
« Last Edit: April 30, 2011, 10:01:56 am by RobB »
57 Red Ed30 manual 5dr, Revo Stage 1
Offline SteveS
Re: What Are Your Revo Settings?
« Reply #106 on: April 30, 2011, 11:37:54 am »
exactly that i have brought up in the past.. dont think i ever got an answer
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline RobB
« Reply #107 on: May 04, 2011, 09:53:05 pm »
Carl from Revo provided the following explanation (thanks Carl!):
"On a stock car with no fueling modifications the fuel setting should always be at 9.  0 is stock as in a stock vehicle, 9 would be used on a vehicle running software without a fuel pump as to stop any potential fuel starvation under heavy loading."
Offline flyboy1976
« Reply #108 on: May 04, 2011, 10:04:25 pm »
9b 5t 6f for me!
Offline SteveS
« Reply #109 on: May 05, 2011, 08:30:16 pm »
9b 5t 6f for me!
b9 in this weather? :-\
SOLD!! :(
Offline flyboy1976
« Reply #110 on: May 05, 2011, 10:10:43 pm »
yup S3 cooler with twintercooler is fine steve, i have found no issues at all i run 856/857/956 depending on my mood
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #111 on: May 08, 2011, 08:57:45 pm »
B7 T5 F9 in my edition 30 and feels immense! :happy2:
Diesel Daily Hack.
Offline RobH
  • Revo stg 2+
« Reply #112 on: May 08, 2011, 09:12:10 pm »
0 is stock and 9 is performance for timing and boost for fuel its F9 been lean and F0 been richer. Technically the leaner yo run the more power you will make but heat is a bi product of been too lean.
Mine is set to B7 T6 F7, you need a hpfp to lower the fuel setting because the standard one will not meet requested. It barely makes requested on F9 with an intake and TBE on stage 2.
Boost set to 9 never felt that great to me good shove in the back low down but seemed to tail off at the top. Where as boost 8 and especially 7 just keep pulling and pulling well into the redline.
« Last Edit: May 08, 2011, 09:14:38 pm by RobH »
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=0sa6hpsc3cmlqecg778fbj8bg5&/topic,19740.0.html
« Reply #113 on: September 09, 2011, 08:24:19 pm »
B6 T6 F9.
Sometime pulling back timing but I was running a dodgy mix of fuel.
Offline Poppa Dom
« Reply #114 on: September 09, 2011, 08:34:23 pm »
Am surprised at running t6, that's quite high. Most common settings at stage 1 are either b6t5f9 or b7t5f9.
Offline chungster
« Reply #115 on: September 09, 2011, 08:38:36 pm »
and i thought he's a cheapskate and only runs 95 RON stuff!  :confused:  :signLOL:
I mean I'm running B6 T3 F5 and with V Power all the time...but then it's cos i'm trying to preserve the poor clutch!
Offline Poppa Dom
« Reply #116 on: September 09, 2011, 08:45:34 pm »
Yes, I hear you - timing = torque, am running mine at T4 currently.
« Reply #117 on: September 09, 2011, 09:19:32 pm »
It was a bit high. Time pull was sometimes a bit high but he said that providing it's run on 98+ I can leave it as it is.
I'm going to run it for a week and then run some logs just to see what's happening. He said the fuel pump was holding up fine and he said it was running 1.3bar boost, is that about right?
Offline Poppa Dom
« Reply #118 on: September 09, 2011, 09:29:48 pm »
Yes, boost sounds fine Rich - definitely worth doing some logging though to look at correction factors - can do a butt dyno using MAF/.81 to give an estimate of power too.
« Reply #119 on: September 09, 2011, 09:32:10 pm »
Thanks dom will post up any findings/problems.
