Author Topic: What Are Your Revo Settings?  (Read 43025 times)
Offline SteveS
Re: What Are You're Revo Settings?
« Reply #30 on: March 18, 2009, 11:10:46 pm »
:p tesco 99
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
« Reply #31 on: March 19, 2009, 09:32:41 am »
I think that Revo assume V-Power is used and tune accordingly.
I'm not saying that Tesco 99 isn't up to it though and I expect that it's the octane which is important.
Offline SteveS
« Reply #32 on: March 19, 2009, 09:40:57 am »
Quote
Boost
Range 0 Valet Mode
Range 1 Stock Boost
Range 6 Performance Boost
Range 9 Aggressive Boost
Timing Adjustment:
Range 0-3 91(US)/95(Euro) Octane Fuel
Range 4-6 93(US)/98(Euro) Octane Fuel
Range 7-9 Unleaded Race Fuel over 100 Octane
Fuel Adjustment:
Range 0 Stock Air-Fuel Ratio (AFR)
Range 9 Performance Air-Fuel Ratio (AFR)
SOLD!! :(
Offline KRL
  • -Receive: 29
« Reply #33 on: March 19, 2009, 11:34:56 am »
The great thing about REVO is the flexibility it gives you.  This means you are able to fine tune your settings for your particular mods.
To take proper advantage of this you really need to be logging with VAG-COM at the same time as adjusting the settings.
For example:
Buy a new intake - Log your Intake Air Mass before and after installation of the intake.  If you are getting significantly more g/s with the new intake you will probably be able to up your boost a little.  Once you up the boost log block 115 in VAG-COM and make sure your actual boost is able to meet your specified boost.
Buy a HPFP - Now you should be able to richen up your AFR a little.  What does this mean?  Well it means you can supply the fuel pump with more fuel which should in turn bring down your Exhaust Gas Temperatures (EGTs).  This means you will be able  to run a some more timing and this is when you will start making some nice power gains :smiley:
Above is just a couple brief examples of what you can do.  There are many many possibilities.  This is the beauty of REVO, the SPS plus and VAG-COM.
« Last Edit: March 19, 2009, 12:55:57 pm by KRL »
« Reply #34 on: March 19, 2009, 11:52:56 am »
Great post, KRL :happy2:
And even without the SPSplus and VAG-COM/VCDS, you can rolling-road or go out with a laptop with a Revo agent and fine tune accordingly.
Offline Golfgirl
« Reply #35 on: March 20, 2009, 03:54:32 pm »
My settings (Stage 1) are T5/B7/F9.
FOR SALE!
Offline illyun
« Reply #36 on: March 20, 2009, 08:00:50 pm »
Mine on Stage 2+ are T6/B1/F9  :ashamed:  and its running 255BHP  :confused: :embarrassed:
Offline SteveS
« Reply #37 on: March 20, 2009, 08:27:26 pm »
er B1????
SOLD!! :(
Offline bacillus
  • -Receive: 453
« Reply #38 on: March 20, 2009, 08:40:54 pm »
Why only 255bhp and Boost@ 1??
Offline SteveS
« Reply #39 on: March 20, 2009, 08:41:44 pm »
boost 1 will explain the "only 255" surely
SOLD!! :(
Offline bacillus
  • -Receive: 453
« Reply #40 on: March 20, 2009, 08:44:15 pm »
Perhaps but it could be a typo so he really needs to revisit this thread for some clarification.
« Reply #41 on: March 20, 2009, 08:45:20 pm »
he is having probs so can only run boost 1
Offline bacillus
  • -Receive: 453
« Reply #42 on: March 20, 2009, 08:52:53 pm »
Hmm, how come he got the car dynoed when it's having problems?   :confused:
« Reply #43 on: March 20, 2009, 08:54:56 pm »
he is trying to find out what the car is doing wrong so put on the dyno to see outputs and vagcom logs i think
Offline WhiteGTI
  • F-A-S-T
« Reply #44 on: March 20, 2009, 09:11:13 pm »
What problems are you having Illyun????  :sad: :sad: :sad: :sad:
2006 E46 BMW M3 - 343hp
