I think the SRS-TEC is the one I was thinking about. Looks fine on their website and decent size pic viewable. I reckon much more reliable source than fleeBay which can be a matter of luck whether a product is good or rubbish unless you already know the trader.
A tip for you if you get one: The extreme right and left sides fixings may be a 'male' flat tab (my OSIR carbon exhaust trim is) and it can work loose. The trim won't fall off but it looks untidy being out of line. Drill a small hole big enough for a cable tie in each of the two side tabs - You'll have to cut and renew the cable ties if you ever want to remove the trim but that's eeeasy-peeasy.
^ Pic of underside but before I did the cable tie mod.
You can see there's plenty of places to tie and secure the trim - There's holes already there in the bodywork.
