Scanned Mandys car today, and its also got issues with rich idle condition, sending on the exhaust emmisions light on since having Revo stage 2 installed by Revo.
From what i can see , it looks like her stock oem filter is to blame for the issue.
I feel Revo have no checked her mods prior to setting her Revo up for her at inters, and not checking what mods the car was fitted with before installing their settings.
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 T HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: VWX7Z0GD3NB7VE
Coding: 040300031C070160
Shop #: WSC 12598 027 411270
VCID: 375B18083FDD
1 Fault Found:
008584 - Bank 1; System too Rich at Idle
P2188 - 008 - Implausible Signal - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 2
Fault Frequency: 2
Mileage: 67096 km
Time Indication: 0
Date: 2000.00.00
Time: 10:35:05
Freeze Frame:
RPM: 782 /min
Load: 27.0 %
Speed: 0.0 km/h
Temperature: 84.0°C
Temperature: 27.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.097 V
Readiness: 0000 0000
She also has this fault which wont clear on vcds, although not causing an issue with the car atm, but keeps re-appearing as soon as its cleared..
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Control Module Part Number: 1K0 953 549 BG HW: 1K0 953 549 BG
Component and/or Version: J0527 051 0100
Software Coding: 0012122
Work Shop Code: WSC 01279 785 00200
Additional Info: XXXXXXXXXXX E0221 002 0010
Additional Info: Geraet 00200
VCID: 78D9DB347243
4 Faults Found:
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
00883 - Ignition Switch (D) Terminal S
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Faulty ignition switch perhaps? any help would be great.
Oh and hope youve had a lovelly Birthday today Mandy!!!
