Author Topic: Problem when fitting passat wing mirror adjuster??  (Read 1034 times)
Offline swiftlupogti
« on: July 04, 2011, 06:28:53 pm »
Dont know whether i'm going crazy here or this is meant to happen?
i have just fitted a brand new chrome passat wing mirror adjuster
part no 5K2 959 565 XSH
when I move it onto L it adjusts the left mirror
when I move it on R it adjusts both at the same time
ive took it out and re- fitted the original and it happens the same on this.is this supposed to happen as ive never noticed it before?
surely when on R it should only adjust the right hand mirror?
Re: Problem when fitting passat wing mirror adjuster??
« Reply #1 on: July 04, 2011, 06:44:24 pm »
R does both  :happy2:
Think it can be disabled with VCDS
Offline welikeaps
  • -Given: 22
« Reply #2 on: July 04, 2011, 06:52:52 pm »
if you have a highline computer you can adjust this setting so it moves the mirrors individually, although I cant remember off hand which setting it is under.
« Reply #3 on: July 04, 2011, 06:55:46 pm »
thanks for your help guys!!
i only have midline so will have to stick with it as it is!!
« Reply #4 on: July 04, 2011, 07:00:49 pm »
Adjust drivers first, then passenger and leave it on 'R' to do them at the same time in the future. I find it quite handy
Offline bacillus
  • -Receive: 451
« Reply #5 on: July 04, 2011, 10:36:53 pm »
You should be able to change this behaviour with vcds.
