Author Topic: Tfsi Mikes Money Pit :: AKS built Cupra :: TTE420 :: Rtech Tuned  (Read 762536 times)
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=e99nml6i4igmvuuuast3u7bsvp&/topic,19740.0.html
Re: Tfsi Mikes Money Pit :: AKS built Cupra :: TTE420 :: Rtech Tuned
« Reply #2925 on: July 12, 2016, 03:11:43 pm »
How long is a piece of string question but...
What sort of life span am I looking at?
Mine have been on 2 years now, hard road use but no track obvs. I would have thought youd get a few years out of them easily.
« Reply #2926 on: July 12, 2016, 03:18:36 pm »
I am the last of the late brakers on track 0:-)
« Reply #2927 on: July 12, 2016, 03:47:17 pm »
I still think they would last you a couple of years... unless you decide to start doing a track day a week over summer.
If you want brakes that will work that you can cook, then I would go down to the 340mm. Cheap as chips.
« Reply #2928 on: July 12, 2016, 03:51:07 pm »
A Trackday a week would be awesome.
Offline xjay1337
  • -Receive: 377
« Reply #2929 on: July 12, 2016, 05:01:56 pm »
I very much doubt you would cook the 340mm discs mate.
They have cooling fins that go all the way through the center, I had zero fade all day.
They are £170 a pair with J-hook and black anti rust coating, bargain really.
« Reply #2930 on: July 12, 2016, 05:22:00 pm »
Not sure if they are compatible with my Calipers?  You on the 340mm TTS discs Jay?
« Reply #2931 on: July 12, 2016, 05:24:40 pm »
Ahh.... good point. They wont work, I dont think.
« Reply #2932 on: July 12, 2016, 05:25:22 pm »
With a different bracket perhaps.
« Reply #2933 on: July 12, 2016, 05:28:22 pm »
Poss.
Whats up with the 370s anyway, I thought you just put some new part worn ones on?
« Reply #2934 on: July 12, 2016, 05:29:43 pm »
Poss.
The have been ground/ skimmed, pads cleaned.  Juddering again.
« Reply #2935 on: July 12, 2016, 05:40:09 pm »
Change the pads?
« Reply #2936 on: July 12, 2016, 05:46:22 pm »
I may get the discs skimmed again to try later on (with P.Mu pads).  Don't want to be chasing my tail.
I need to check the min thickness for the brembos and the runout measured
Offline xjay1337
  • -Receive: 377
« Reply #2937 on: July 12, 2016, 07:30:28 pm »
Ahh yes I remember you have different caliper setup to us...  :thinking: :thinking:
as long as after skimming you are still over minimum disc thickness... also any pad build up could bake into the disc and cause it to get uneven heating so vibration may return later.
« Reply #2938 on: July 12, 2016, 07:34:00 pm »
2 sets of rotors done it to me.  Lets see if AP are better than Brembo
« Reply #2939 on: July 12, 2016, 07:35:58 pm »
NOthing to do with the rotors... its the pads
