April 09, 2025, 02:18:11 am
All Things Mk5
Mk5 General Area
Charcoal canister pipe assembly.
Pages:
Topic: Charcoal canister pipe assembly. (Read 6117 times)
martziniuk
Won't Shut up.
-Given: 25
-Receive: 18
Re: Charcoal canister pipe assembly.
Reply #15 on:
August 04, 2011, 06:40:52 pm »
The previous owner of mine must have brimmed the tank regularly so I just replaced the canister and now fill to the first pump click.
Mk2 Octavia vRS with K04 conversion, 3"TBE & Decat, APR HPFP, BDM Intake, S3 I/C, Sachs clutch & Unicorn custom map, S3 brakes, AP coilovers, THS mounts.
B8.5 Audi S4 with uprated pulley and unicorn Stage 2
Bo!
Always Involved
-Given: 0
-Receive: 3
Reply #16 on:
December 18, 2018, 08:03:53 pm »
Any ideas what the part number is for item 3 in the diagram can’t find it anywhere.
v4rley
Just look at my post count
-Given: 29
-Receive: 104
Reply #17 on:
December 18, 2018, 08:20:03 pm »
I cannot either, I just looked at the one on the car and no luck as it’s seems to have worn off.
pudding
Global Moderator
-Given: 2
-Receive: 690
Reply #18 on:
December 19, 2018, 12:35:36 pm »
Worn off on mine too. It's on a different EKTA diagram, probably the intake manifold.
v4rley
-Given: 29
-Receive: 104
Reply #19 on:
December 19, 2018, 12:43:48 pm »
1K0 133 366 BB
DBXdarkangel
Always Involved
-Given: 18
-Receive: 9
Reply #20 on:
December 19, 2018, 02:14:38 pm »
I changed my charcoal canister because of the vcds scan fault and changed the selenoid and guess what? Still got the fault code and no symptoms.
Bo!
Always Involved
-Given: 0
-Receive: 3
Reply #21 on:
December 19, 2018, 02:33:27 pm »
Thanks for the part number v4rley.
unfortunately for me it’s been diagnosed as a leaky injector seal on number 1, not the hose.
ZemHoopoke
Reply #22 on:
December 28, 2018, 02:14:43 pm »
Looks like the pipe might have been in a bind from the position it is in now that is if it is still bolted to the motor in that picture.
Ads22
Always Involved
-Given: 7
-Receive: 1
Reply #23 on:
December 29, 2018, 04:33:17 pm »
Mines also now producing a fault code for this. How do you determine if its definately charcoal canister or leaky injector? If this is also left for a prolonged amount of is there any potential damage that can be caused.
Pages:
All Things Mk5
Mk5 General Area
