Author Topic: Remove DSG gear stick  (Read 6647 times)
Offline aidman
« on: August 07, 2011, 08:42:13 pm »
Hi all,
I have a DSG gearstick and for the past 10k miles, the stitching on the gearstick has started to come apart to a point where I need to get it off the car and in the house where I can attempt to fix it... My problem is I can't work out how you remove the gear stick from the actual gear selector unit, it appears to be locked in place..? I'm sure others have done this before and I'm sure there must be a guide out there, but I just can't find it... Help...
 :drinking:
Offline edd666999
  • -Receive: 89
Re: Remove DSG gear stick
« Reply #1 on: August 07, 2011, 08:47:30 pm »
i do believe i have stolen these from very cherry :P
« Last Edit: August 07, 2011, 08:49:36 pm by edd666999 »
Offline aidman
« Reply #2 on: August 11, 2011, 09:47:40 pm »
Guide is spot on (as to be expected)! Many thanks EDD666999, very cherry  :drinking:
Offline GTI-Ross
  • Learning All The Time :)
« Reply #3 on: January 26, 2013, 06:14:14 pm »
How do you actually get the gear knob off / detach from the gaiter?
