Author Topic: Changing the gearbox oil  (Read 12314 times)
Offline gazbutS3
« on: August 09, 2011, 04:53:58 pm »
Does anybody have a link/info on changing the gearbox oil? type, quantity, method??? Thanx :happy2:
manual  :smiley:
Offline s3dubbin
Re: Changing the gearbox oil
« Reply #1 on: August 09, 2011, 05:01:31 pm »
Doing mine at the wkend Gaz. Done 41k so prob due a change. 2.5ltrs i think and it reads g052 171 a2. Stevie.
Offline gazbutS3
« Reply #2 on: August 09, 2011, 05:03:36 pm »
Thanx for the reply Stevie, as for the topping up, what is the correct level, do you fill untill it flows from the fill port or something???
« Reply #3 on: August 09, 2011, 05:10:28 pm »
Interested also. Easy enough job? Want to top up as drive shaft oil seal has been leaking.
Will top it up, get it fixed pay day and then fresh oil to gimme something to do one weekend.
Offline s3dubbin
« Reply #4 on: August 09, 2011, 08:04:36 pm »
Havnt done it before so cant come across with an idiot guide yet. Cant see it being difficult, similar to an engine oil change with the plug in and out, run it then top it up. Stevie.
Offline gazbutS3
« Reply #5 on: August 09, 2011, 08:24:42 pm »
I'm sure i read somewhere about putting so much oil in, running it up, then topping it up but can't remember where I read it :laugh:
Offline s3dubbin
« Reply #6 on: August 14, 2011, 05:22:36 pm »
Have you changed your gearbox oil yet Gaz? Changed mine just now, drain plug and fill plug (30nm), just over 2.3ltrs? Bloody hell it was really sh*tty oil that came out and full of metal shavings. Nice and clean now. Stevie.
Offline shugyboi
« Reply #7 on: August 14, 2011, 10:17:30 pm »
do you need to change the oil in the dsg boxes?
first auto so sorry if its a daft q  :rolleye:
Offline s3dubbin
« Reply #8 on: August 15, 2011, 06:34:11 pm »
Not an expert but i would say so and i think they hold a lot more oil than a manual. Stevie.
Offline S44rje
« Reply #9 on: August 16, 2011, 11:50:59 am »
You need to keep filling it up until it starts to drip out.
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
« Reply #10 on: February 05, 2012, 09:49:32 pm »
Anyone else been changing their manual transmission fluid?
« Reply #11 on: February 05, 2012, 10:07:46 pm »
Nope. Any advice on when to change it, type of oil etc?
  • -Given: 88
  • -Receive: 95
« Reply #12 on: February 05, 2012, 10:43:10 pm »
Every 4 years or 40k miles.  Use only genuine fluid from the stealers.  Transmission fluids are a nightmare to get right otherwise.
Transmission oil goes 'off' in a very different way to engine oil, and most manual transmissions dont have a filter either, so all the brass filings from the synchro rings just keep building up and making more of a soup.
« Reply #13 on: February 05, 2012, 11:07:03 pm »
Dammit. I've missed out - had 4th year service in December. Is it something worth getting the stealers to do?
  • -Given: 88
  • -Receive: 95
« Reply #14 on: February 05, 2012, 11:28:10 pm »
How are your gear shifts?
Gearbox oil isn't really critical - it is more to do with smoother shifts, especially in cold weather on start up, and to help prevent sloppy shifting much later in the boxes life.
Probably be perfectly OK to wait until your next routine service.
Gearbox oils, and rear axle oils MUST be drained when hot, ideally after a good spanking - so when you do get round to getting it done, state you want the oil drained the moment you leave it at the stealers.
