Author Topic: high oil usage, any ideas?  (Read 31602 times)
Offline heavyd
  • -Receive: 29
« on: August 14, 2011, 02:47:00 pm »
I've been going though a lot of oil lately, used a litre in 3 weeks,roughly 600miles. There isnt any leaks anywhere, but there are a lot of black dots on my rear bumper, any ideas? turbo seals?
Offline RacerMH
    • MH Racing
Re: high oil usage, any ideas?
« Reply #1 on: August 14, 2011, 03:23:28 pm »
I'm just guessing here, so don't get too panicked, but could be turbo seal on it's way out. Has the turbo got louder at all? Less serious alternatives could be something as simple as a leaking sump plug. Have a check underneath to see if you can see if there's any oil anywhere. Has the car been serviced recently?
2008 Black Magic Pearl 3dr Golf GTI
Offline heavyd
  • -Receive: 29
« Reply #2 on: August 14, 2011, 03:31:13 pm »
turbo isnt any louder, but there iasnt any traces of oil anywhere under the car at al
Offline martziniuk
« Reply #3 on: August 14, 2011, 04:51:26 pm »
That is quite a lot, how many miles per litre were you geting before?
Mk2 Octavia vRS with K04 conversion, 3"TBE & Decat, APR HPFP, BDM Intake, S3 I/C, Sachs clutch & Unicorn custom map, S3 brakes, AP coilovers, THS mounts.
B8.5 Audi S4 with uprated pulley and unicorn Stage 2
Offline bacillus
  • -Receive: 451
« Reply #4 on: August 14, 2011, 05:13:19 pm »
Yeah but if he took it to VW they would probably say it's within their limits i.e. 600 miles/litre max
Offline heavyd
  • -Receive: 29
« Reply #5 on: August 14, 2011, 05:23:25 pm »
Its still a bit worrying though!!
Offline edd666999
  • -Receive: 89
« Reply #6 on: August 14, 2011, 05:29:43 pm »
mine did this, after only topping it up to 1/2 way between 1/2 n max it stopped. ave a feeling it was burning it off.
Offline PDT
  • -Receive: 142
« Reply #7 on: August 14, 2011, 07:10:32 pm »
Compression test would be a good start Dom. Not a Halfords £20 type tool, a leakdown test.
Offline gobbleplease
  • -Given: 64
  • -Receive: 48
« Reply #8 on: August 14, 2011, 07:21:57 pm »
My old gti munched a litre every 1000 miles, a few people on here had it worse,
saying that my new gti hasnt used any yet !
MK7 GTI - ARRIVING DECEMBER
Offline heavyd
  • -Receive: 29
« Reply #9 on: August 14, 2011, 08:14:27 pm »
I only filled it the day before the Rr day dave, went on hols for a week, checked it Friday and it was below minimum :stupid:
Think I've got a wheelbearing on it's way out now aswell :sad1:
Offline vRSAlex
  • -Receive: 253
« Reply #10 on: August 14, 2011, 10:10:42 pm »
Does the car smoke slightly on idle?  Or on over run?
Most of the time its turbo, then stem seals, then rings.  Worth seeing how caked up the plugs are if at all.
Follow AKS tuning on Facebook
Offline itismebigd
« Reply #11 on: August 15, 2011, 09:21:03 am »
Hi Heavyd, i agree with what your saying here,for a month or two there my gti has also been sore on oil too,took it to stealers and they inspected it and came back to say "it is within the normal  running perimmiters of the car" not quite sure what that means lol but there was no leaks so look forward to your out come for this post thanks Dougie
Offline martziniuk
« Reply #12 on: August 15, 2011, 12:45:58 pm »
How much were you using before? If your running more boost you will use a little more oil but unless someone knows different I believe that's beyond VAG limits.
Offline heavyd
  • -Receive: 29
« Reply #13 on: August 15, 2011, 06:17:32 pm »
there isnt any smoke at all on idle, them when you drive, occasionally theres a large cloud :confused:
Plugs dont look very healthy IMO, but I'm no expert!
Could it be anything to do with the high boost at 3000rpm?
This is how bad the tailgate and bumper is
Offline swgti
  • -Given: 28
« Reply #14 on: August 15, 2011, 07:15:17 pm »
Yikes looks like most of it flying out the back of the exhaust then! :confused:
