Author Topic: Changing seats  (Read 1544 times)
Offline sf1506
Changing seats
« on: August 21, 2011, 07:41:14 pm »
I've got myself some new seats and just wondering how easy it is to change over, ie air bag etc.
Is there any body that has done this??
Offline mortygttdi
  • -Receive: 146
Re: Changing seats
« Reply #1 on: August 21, 2011, 07:52:23 pm »
Did you buy Ali's GTD seats mate :happy2: if so I have the exact same seats and its just a simple swap of the airbag plugs. Unless your wanting to get the heating part sorted??? if so then its going to be a bit more involved but not a problem.
Darren
Offline sf1506
Re: Changing seats
« Reply #2 on: August 21, 2011, 07:56:55 pm »
Yes I did mate, do you need to disconnect the battery to chance the fronts for the air bags in the seats?.
Offline big al
Re: Changing seats
« Reply #3 on: August 21, 2011, 10:03:53 pm »
Don't think you do, the airbag light may come on the dash afterwards, but it should go off if you stick the VCD on it.
Offline mortygttdi
  • -Receive: 146
Re: Changing seats
« Reply #4 on: August 21, 2011, 10:23:17 pm »
personally I think i took the negative off the battery, do the swap and then has long has every thing is okay the seats will be fine.
Darren
Offline sf1506
Re: Changing seats
« Reply #5 on: August 22, 2011, 10:37:58 pm »
I think I'll disconnect the battery to be on the safe side, hopefully the air bag light won't come on when I'm done.
 does any body know what size trox bit to fit the front seats??
Offline ali6n2
Re: Changing seats
« Reply #6 on: August 22, 2011, 11:55:39 pm »
i disconnected the battery mate and all was fine, second time round i didnt and the airbag light came on.
