Author Topic: Can anyone help me??? Windows Vista???  (Read 5329 times)
« on: August 27, 2011, 11:39:54 am »
Hello everyone,
Well a friend of mine put windows 7 on my Hp laptop about 6 mths ago assuring me that I wouldn't have any probs with licence issues. He told me something along the lines that it was a company product with many licences.
However since I had my laptop on auto updates I recently started getting messages about being a victim of software fraud. The guy to take no notice of them..... so I did.
I switched on the other day but nothing. I tried various start up options but it says no OS found  :confused:
So I don't know what to do???
I just want to add that my laptop originally came with Vista home ed, but it didn't come with a windows disc, and I never made a backup  :ashamed:
I do have the original product key underneath though.
Can I simply buy a copy of the vista program, run it and add my product key???
......has any got said disc?
Any advice is really appreciated.  :happy2:
Carlo. :smiley:
Offline maxload
  • -Given: 41
  • -Receive: 29
  • Edition30 - No.1819
Re: Can anyone help me??? Windows Vista???
« Reply #1 on: August 27, 2011, 12:54:25 pm »
It sounds to me like your 'freind' installed a pirated version of windows7. You could try booting from the disk again and running system restore. But if it is a pirated disk and you are recieving these update messages from microsoft then i'm affraid you've had it.
« Reply #2 on: August 27, 2011, 01:12:57 pm »
He probably installed a copy with an 'activator' patch. It's when updating / sending data to microsoft it's normally detected.
Don't understand why its found no os though. Normally a symptom of hard drive failure that.
Has it had a knock or bump?
« Reply #3 on: August 27, 2011, 01:14:33 pm »
The product key is the important thing so grab a Vista disc and then use your key on it. Alternatively, buy Windows 7. I'd always recommend the OS is a proper version irrespective of what you run on there.
Offline bacillus
  • -Receive: 453
« Reply #4 on: August 27, 2011, 01:14:57 pm »
If you can get into bios then see if your hdd is seen as one possibility is that it's failed.
Another possibility is your master boot record is screwed; if this is the case you can try booting off the win 7 dvd and choose repair my computer.
Offline bacillus
  • -Receive: 453
« Reply #5 on: August 27, 2011, 01:25:56 pm »
Carlo what version of vista were you previously using and was it 32 or 64 bit?
« Reply #6 on: August 27, 2011, 02:13:52 pm »
Well I know it's not been bumped or dropped.
Any ideas where I can get a vista disc?
I sorta think it's 64 bit but I will check when I get in later. Also I'll check the bios for the HDD.
I popped into a local pc shop and the guy said £45 to fix and he will give me the discs but they won't be original discs.
Does that sound ok???
Thanks for all the help so far guys  :drinking:
Offline bacillus
  • -Receive: 453
« Reply #7 on: August 27, 2011, 02:28:54 pm »
I would want an original MS disc and licence as he may be offering you a cracked version that he's burned himself.
If it's 32 bit then I have an unused ultimate version copy and licence hanging about somewhere...
« Reply #8 on: August 27, 2011, 06:02:21 pm »
Well I checked and tbh im not sure what it is...
I have taken a photo of the bios page, but trying to copy and paste a link from photobucket using an iPhone is near impossible.
Here is a link to my page...
(not sure if it will tell u any info)
http://s612.photobucket.com/albums/tt210/monte0797/?action=view&current=photo.jpg
« Reply #9 on: August 27, 2011, 06:25:42 pm »
We'll Mike,Bacillus,
You might have been right all along. I think the HDD has had it :sad1:
Any ideas on how to get it sorted???
Here is a photo of the bios diagnostic check of the HDD...
http://s612.photobucket.com/albums/tt210/monte0797/?action=view&current=photo-1.jpg
« Last Edit: August 27, 2011, 06:34:57 pm by monte »
« Reply #10 on: August 27, 2011, 07:01:39 pm »
You could buy a replacement HDD cheap enough.
3x tiny x head screws and it should pull out.  Ifti deals in components I think or your local computer shop.
Offline bacillus
  • -Receive: 453
« Reply #11 on: August 27, 2011, 07:38:20 pm »
Or step up and get a refurbished ssd.   :evilgrin:
http://www.mk5golfgti.co.uk/forum/index.php/topic,34086.0.html
« Reply #12 on: August 27, 2011, 07:46:30 pm »
Would be a good peeformace upgrade, the your computer will be ready for stage2+ then lol
« Reply #13 on: August 28, 2011, 10:25:00 am »
So if I buy a hard drive how easy is it to get up and running again with windows on.
Will I still be able to use vista with the product key under the laptop.
Do I need to buy a vista disc?
Where is the best place to buy the things I need?
Really sorry for all the newb questions.  :ashamed:  again.
« Reply #14 on: August 28, 2011, 10:33:26 am »
Physically swapping it is simple enough.
When the new one is back in; re enter bios > set primary boot device to DVD drive > start computer with windows disc in > follow installation instructions on windows setup.
You should be able to use the vista disc that came with it (have I got you right?) and the key on the computer.  :happy2:
