Author Topic: Do i have a jack?  (Read 2749 times)
Offline golf nutter
  • -Given: 19
Do i have a jack?
« on: August 27, 2011, 11:46:53 am »
i was going to swap my wheels around today, putting the rears on the fronts and vice versa due to the rears having more tread.  my car doesnt have a spare wheel (08 GTi) but has some foam and a compressor.  should it also have a jack???  there seems to be a cut out in the boot tidy thing that holds the other stuff.  if it doesnt come with one then i shall get a trolley jack.
Re: Do i have a jack?
« Reply #1 on: August 27, 2011, 11:51:38 am »
I think if you had a spare wheel, then you'd have a jack too. Mine certainly does, though rather crap for much than emergency stuff. Imports had the foam stuff instead, which is what you might have.
If you're going to swap wheels around, get a proper trolley jack. Just a lot easier and safer to use IMO.
Offline golf nutter
  • -Given: 19
« Reply #2 on: August 27, 2011, 11:54:05 am »
are you saying that generally the cars came with spare wheels?  was the foam system an option or was it only reserved for parallel imports...sure mine is standard uk car.  :confused:
« Reply #3 on: August 27, 2011, 12:23:42 pm »
Yup. Unless someone has deliberately replaced it, it's generally an import. Where was the PDI done?
Offline GarethB
« Reply #4 on: August 27, 2011, 12:42:06 pm »
I thought that you had to pay extra for the spare wheel & associated kit these days....
« Reply #5 on: August 27, 2011, 12:56:45 pm »
Depends on the make/model. But the MK5 and MK6 both come with a space saver spare wheel and jack as standard. Have a look on the VW website.
Offline golf nutter
  • -Given: 19
« Reply #6 on: August 27, 2011, 01:00:58 pm »
i will check after the F1 qualifying!  any other way of knowing if its a parallel import?  think i am going to get a trolley jack and axle stands tomorrow.
Offline GarethB
« Reply #7 on: August 27, 2011, 01:11:21 pm »
Cheers Mr Wolf - I was going on what I was told by Skoda when looking at a new Octy vRS a couple of months back. Just assumed that the same applied to VWs when buying my 07 GTI.
« Reply #8 on: August 27, 2011, 01:12:17 pm »
Wouldn't surprise me if the dealers took the stuff out and sold it on, only to fob you off with a foam and compressor kit.
« Reply #9 on: August 27, 2011, 01:39:57 pm »
I'll second that from experience, only use the roadside jack in an emergency.
Used it when changing rear brakes, just before I could slide axle stand all the way under the jack failed and the car landed on the jack.  The sill took the weight of the car landing back on the extended jack. Left a nasty dent in my sill  :fighting:
Offline golf nutter
  • -Given: 19
« Reply #10 on: August 27, 2011, 02:39:29 pm »
so is there any other way of telling if it's a parallel import or not?
regardless, i will definately be buying a trolley jack tomorrow...what happened to you Mike is the kind of situation i want to avoid.  must be gut wrenching when that happens.  i remember when i bought a cheap-ish paddock stand for my ducati 748 and whilst single handedly putting it on one of the little wheels flew off and the bike landed on its side  :sad: :sad:
« Reply #11 on: August 27, 2011, 02:45:49 pm »
Was devastated going to cost in the region of 300 quid to out right :(
Offline 182_blue
  • -Receive: 54
« Reply #12 on: August 27, 2011, 03:13:43 pm »
Does it have an alarm ?, what does it say in the service book ?
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #13 on: August 27, 2011, 05:05:16 pm »
.............front wheel drive & it's recomended to have the best tread on the rear wheels,less chance of the rear letting go. I would leave alone.
Offline golf nutter
  • -Given: 19
« Reply #14 on: August 27, 2011, 06:29:51 pm »
yes it has an alarm.  no stamp in what i think is the pdi section, it has full vw history, the first stamp being at 12k...probably looking like a european parallel import i reckon...which is fine, my mk4 gt tdi pd130 came direct from Holland to the UK to its first owner.
i have checked out all the option codes and the first one on the sticker turns out to be this...
B0N = Component parts set, complying with vehicle type for Great Britain, various parts
does that shed light on parallel import or not?
i always thought the advice was that the driven wheels should have the better tread.  there's not a great deal of difference between front and rear tyres but enough to make me think that i would rather have more tread at the front.  i know what you mean about the rear though, however i think it would have to be a pretty dynamic event to have the rear come round, i dont think simply the tread would make that happen.
« Last Edit: August 27, 2011, 07:00:20 pm by golf nutter »
