Author Topic: Replacing transmission fluid, manual gearbox  (Read 3871 times)
Offline Black9
  • -Given: 35
« on: August 27, 2011, 02:37:39 pm »
Never seen this mentioned on the forum!? Shouldn't this be done at least once a year? I used AMSOIL MTF on my old Type R, guess this would be ok on the 5 too? How easy is it to replace and is it a "sealed for life" like BMW?
Re: Replacing transmission fluid, manual gearbox
« Reply #1 on: August 27, 2011, 02:39:29 pm »
I think GazbutS3 has done his recently  :happy2:
Offline s3dubbin
« Reply #2 on: August 27, 2011, 02:49:44 pm »
I was posting on this topic  a couple of weeks ago. It has been mentioned once or twice. Its an easy job, easier than engine oil and not sealed for life. Stevie
Offline Black9
  • -Given: 35
« Reply #3 on: August 27, 2011, 07:04:24 pm »
Easier than engine oil? Is the drainage hole and fill-up plug on the gearbox, beside each other?
Offline Black9
  • -Given: 35
« Reply #4 on: August 27, 2011, 07:05:15 pm »
What oil do people usually use, VW specific?
« Reply #5 on: August 27, 2011, 09:31:51 pm »
How often should this be done? Any idea of costs involved? It's not something I'd attempt myself.
MPS
« Reply #6 on: August 27, 2011, 11:31:20 pm »
+1, This is definitely a topic that you hardly ever hear about, especially regarding the 'sealed for life' part. I can't say I've ever read anywhere in the manual saying it should be changed though so I assumed it was sealed for life.  :confused:
Slightly worrying when someone on here changed their gearbox oil a few weeks back and said they found bits of metal in the oil!  :surprised:  :scared:
Nasir
« Reply #7 on: August 27, 2011, 11:39:55 pm »
That would be from the break in period, quite normal I suppose.
Offline Black9
  • -Given: 35
« Reply #8 on: August 27, 2011, 11:56:48 pm »
Someone finding pieces of metal in the oil is not good, especially as VW don't mention replacement once as the same with most manufacturers :stupid:
« Reply #9 on: August 28, 2011, 08:55:40 am »
Shame there aren't magnetic drain plugs same as the ecs sump plug
Offline vRSAlex
  • -Receive: 253
« Reply #10 on: August 28, 2011, 09:01:18 am »
Easy to drain, but a pain to fill unless you have a pump.
I use the millers competition oil in my box and all the ones that come in for a change.
Follow AKS tuning on Facebook
« Reply #11 on: August 28, 2011, 09:02:43 am »
What sort of mileage should it be done?  What do you charge Alex?
Offline vRSAlex
  • -Receive: 253
« Reply #12 on: August 28, 2011, 09:15:52 am »
For piece of mind I would change the oil every 40k ish. Most of the cars on here get driven fairly hard and on track. The upgrade to the Millers oil can help smooth out changes and will prolong the life of the box.
The oil change would be around £60 plus vat.
« Reply #13 on: August 28, 2011, 09:22:44 am »
Wouldve been done when the clutch was done, will use the millers on the next clutch swap, thanks :happy2:
Offline lee_
« Reply #14 on: August 28, 2011, 09:54:01 am »
You'll also need a special tool to pull the fill and drain plugs, IIRC a Sealey M16 security spline tool does the job (about £6 on eBay).  :happy2:
