Author Topic: Datalogging session done  (Read 3946 times)
Offline bacillus
  • -Receive: 451
Re: Datalogging session done
« Reply #15 on: September 04, 2011, 07:37:51 pm »
cheers. what would cause such a big difference in boost actual to requested?
If you are not the original owner then the previous owner may have tweaked the oem actuator pre-tension or replaced it with a forge one.
Nasir
« Reply #16 on: September 04, 2011, 07:48:10 pm »
The previous owner was a woman :signLOL:
Offline Russ_leeds
« Reply #17 on: September 04, 2011, 07:53:25 pm »
Yeah one previous owner was a woman so doubt it's been tampered with. Could this cause any damage?
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline bacillus
  • -Receive: 451
« Reply #18 on: September 04, 2011, 08:29:17 pm »
What sort of boost are you seeing bearing in mind that the standard gti map sensor can only measure pressure up to 2580mbar as seen in vcds?
Offline Russ_leeds
« Reply #19 on: September 04, 2011, 09:05:17 pm »
iirc the requested was about 400 and the actual was 999 on idle
Offline bacillus
  • -Receive: 451
« Reply #20 on: September 04, 2011, 09:11:32 pm »
Any chance you could post the boost logged data?
Offline Russ_leeds
« Reply #21 on: September 04, 2011, 09:15:45 pm »
unfortunately the log didnt save for some reason :sad1:
fuel rail pressure was matched all through the rev range
Offline heavyd
  • -Receive: 29
« Reply #22 on: September 04, 2011, 10:20:11 pm »
990 is fine on idle. its the actual atmospheric pressure. I dont think I've ever seen it go any lower than that
Strange, I have logs that show actual boost as  2860mb :stupid:
Offline Russ_leeds
« Reply #23 on: September 04, 2011, 10:56:29 pm »
good to hear cheers mate
Offline bacillus
  • -Receive: 451
« Reply #24 on: September 04, 2011, 11:13:39 pm »
The standard gti has a 2.5mbar map sensor. iirc the ed30 has a 3mbar one.
Offline mortygttdi
  • -Receive: 146
« Reply #25 on: September 04, 2011, 11:48:43 pm »
The boost will always sit at 1000mbar the requested is only a minimum :happy2: i.e boost limit too low...
On a mapped car it would probably show 2540mbar at max on VCDS, your car is fine Russ just get the plugs changed and or the coilpacks, VW will do the coils under warranty re the recall notice.
Darren
Offline Russ_leeds
« Reply #26 on: September 05, 2011, 08:28:12 am »
cheers darren :happy2: unfortunately when i phoned vw about the coilpack recall its not included as its a late 07 plate :sad1:
