Author Topic: Nearly finished, thoughts on final tweeks !  (Read 4433 times)
Offline Carrera2RS
« on: September 04, 2011, 08:03:11 am »
Current Spec
Pirelli 58 3 door.
Chassis :
Bilstein  PSS10, WALK, TT alloy lower arms and ball joints, TD 8x18, VWR front brakes, neuspeed ARB's, All camber and ride heights tweeked adjusted and now finished.
Engine:
TT bottom engine mount, Miltek TBE, REVO stage 2, K&N panel filter, Forge DV, Neuspeed quickshift.
I am unhappy with the vibration of the THS bottom mount, would like to see how I can reduce wheel hop and manage vibration ?
Quite interested in Whiteline bumpsteer kit to be fitted at the same time ?
I also find the engine seems particularly sweet and crisp most of the time but occasionally seems a little fluffy, is it worth changing the Forge DV for a late original DV ?
Tks for thoughts
Offline Poppa Dom
Re: Nearly finished, thoughts on final tweeks !
« Reply #1 on: September 04, 2011, 08:55:20 am »
IMHO I would be running the latest revision DV over the Forge one.  :happy2:
« Reply #2 on: September 04, 2011, 09:06:03 am »
What reason? Thanks  :happy2:
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=omi43t0iem0uf3gqqej2euofo8&/topic,19740.0.html
« Reply #3 on: September 04, 2011, 09:13:27 am »
Have you thought about running some "semi-track" tyres? More grip should equal less or no wheel hop.
Yoko ad08 or maybe Hankook rs2?
Offline vRSAlex
  • -Receive: 253
« Reply #4 on: September 04, 2011, 10:10:48 am »
Stickier tyres can create more wheel hop I've found.  All depends how much power you are running too.
The hankook rs2 tyres are now discontinued.  The rs3 replacements are not UK road legal.  Damn annoying as they were a top cheap track tyre.
Follow AKS tuning on Facebook
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #5 on: September 04, 2011, 10:50:28 am »
@ OP
What was your final Geometry settings?
I have the TT arms & ball joints going on this week, along with the bumpsteer kit
I'm lowered on 30mm H&R springs, Bilstein B8's and running 7.5J 18 OEM monzas with WALK also
Any help would be much apperciated as i've read all previous threads on this subject but am none the wiser :stupid:
« Reply #6 on: September 04, 2011, 10:56:02 am »
Yeah i suppose your right. I was just thinking along the lines of.... Sticky tyres - more grip - shouldn't lose traction as easily.
Offline Poppa Dom
« Reply #7 on: September 04, 2011, 03:59:08 pm »
Well, I had one on mine did loads of logging and when compared against the latest oem dv I saw that the OEM was holding boost better than the Forge. Could be a nuance on my car, so not necessarily something that everyone would see. This was particularly at the top end.
Dom
Offline Janner_Sy
  • -Receive: 113
« Reply #8 on: September 04, 2011, 04:06:18 pm »
More grip will cause the engine to rock back more violently on acceleration which causes the 'hop' sensation which breaks the traction of the tyre, so ECU cuts power to regain traction, engine goes forwards again for the sequence to repeat.
I definitely had more wheel hop when i moved to stickier tyres.
« Last Edit: September 04, 2011, 04:10:40 pm by Janner_Sy »
« Reply #9 on: September 04, 2011, 04:08:12 pm »
Thanks I changed the spring on my forge but may try a revision DV to see if there is a difference
What kind of pressures are you getting & what state of tune?  :happy2:
Offline Poppa Dom
« Reply #10 on: September 04, 2011, 04:18:28 pm »
1.68 bar, ST2+ on ko4  :happy2:
« Reply #11 on: September 04, 2011, 04:19:50 pm »
If you're happy at that I'd willingly try one to see the difference...
Offline Carrera2RS
« Reply #12 on: September 05, 2011, 11:56:11 pm »
@ OP
This thread might help http://www.mk5golfgti.co.uk/forum/index.php/topic,28835.0.html
I currently run 3-5mm higher but this was the base settings :
Ride height 338 mm
Camber L -2 deg 10 mins, R -2 Deg 0 mins
Toe L - 6mins, R - 6mins (toe out)
Caster L 8 deg 13 mins, R 8 deg 14 mins
SAI L 16 deg 36 mins, R 16 deg 21 mins
Bilstein PSS10 setting 3/10
Neuspeed 25mm bar full soft
WALK
Tyre pressure 35 psi after a 20 minute normal journey (32.5 cold)
Tyre Pirelli P Zero 225/18 92Y XL MO
Rear
Ride height 324mm
Camber L -1 deg 37 mins, R -1 deg 30 mins
Toe L 6 mins, R 7 mins (toe in)
Bilstein PSS10 setting 4/10
Neuspeed 25mm full hard
Tyre pressure 33.5 psi after a 20 minute normal journey (31.5 cold)
Offline Carrera2RS
« Reply #13 on: September 05, 2011, 11:57:05 pm »
Dom, hi
I'll check the one that came off, a late 08 Pirelli might have a late version ?
Offline Poppa Dom
« Reply #14 on: September 05, 2011, 11:58:58 pm »
Possibly - will be obvious once you see it as ETKA PN clearly visible  :happy2:
