Author Topic: ESP Light permanently on :S  (Read 11265 times)
Offline dub singh
  • Snakebite Chasers...
« on: September 18, 2011, 11:37:26 pm »
Driving home today and the ESP light came on and stayed on... turned the engine off, back on and the light remained on?
The cars a 1.6 FSI 2006, 28k on the clock
Anyone got any ideas?
If you're having Audio problems i feel bad for ya son... I've got 99 problems but Bass aint one!
Re: ESP Light permanently on :S
« Reply #1 on: September 19, 2011, 01:34:22 am »
I can scan it for you tomorrow night if you want. NW London
Offline calculon
« Reply #2 on: September 19, 2011, 06:32:25 pm »
Any other strange behaviour? Might be the MAF sensor.
Offline dub singh
« Reply #3 on: September 19, 2011, 08:37:07 pm »
Cheers for that mate...
Apparently its a VERY common fault with mk5's, a fault that VW are all to very familiar with!
It's to do with a ABS/brake pump sensor and costs £1500 to rectify! VW will only cover it under warranty, but will offer a "good will service" which comes with its own terms and conditions..  :sick:
apparently theres thousands of mk5's with this sort of problem, mostly on 1.6's..
« Reply #4 on: September 19, 2011, 08:40:27 pm »
I have heard of these failing...
If your about in the morning i can scan it for you.
Offline gillm
« Reply #5 on: September 19, 2011, 08:50:32 pm »
i had this its a easy job to replace and i have a spare pump if needed . i also have  the old top half of my pump which you can get rebuilt here
http://www.ecutesting.com/vw_golf_touran_abs_pump_module.html?gclid=CILZ56qKqqsCFcMOfAodYAJQZQ
eaither way its a diy job with a brake bleeder and vag.com
west tuned gt28 @ 340hp
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #6 on: September 19, 2011, 08:52:47 pm »
VW have now introduced a repair kit which is a good bit cheaper than a new pump
Cluster and Key coding
Location Great Yarmouth
Offline dub singh
« Reply #7 on: September 19, 2011, 09:09:36 pm »
Cheers Richwig83  :happy2:
I got it scanned today, and it confirmed the worst... fault code - 01435 (G201) sensor - which is the ABS brake pump sensor module...
Even tho VW are fully aware of this problem, they're very reluctant to help.. some dealerships worse than others...
If your cars under warranty not a problem..
if its out of warranty they will offer a 'good will offer' of between 25 - 50% only if you're cars been serviced at VW?
The faulty part is non-servicable so i dont see what the service history has got to do with it? It's a fault with the braking system, that VW are aware of, even mentioned in the Gaurdian newspaper and yet they're still so reluctant to do anything..
the new repair kit is £600  :sick:
Offline gillm
« Reply #8 on: September 19, 2011, 09:18:30 pm »
I have a pump you can have for £100 if needed
Offline marko
« Reply #9 on: December 13, 2013, 11:25:32 pm »
bit of a thread resurrection ...
got this fault this morning as i drived to work and hasnt gone out since
01435
brake pressure sensor 1 (G201)
012 electrical fault in circuit
anyone have the part number for the repair kit for the pump???
TIA
mark
2007 TR gt170...heated leather,underseat drawers,auto-levelling bi-xenons,puddle leds,chrome switches,footwell lights f+r,cruise control and ed30 rear lamps,LED interior....carbon highline clocks,ed30 front spoiler,RNS 510 P+MDI,mk6 gti gearknob,TPMS done,complete r32 trim kit+ MFSW,r32 f+r brakes,RLS fitted.headlamp washers,folding mirrors and boot pop,mk6 RVC,19"Helios,AP coilies,valeo LEDs  ...dpf delete and remap to finish off
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #10 on: December 13, 2013, 11:51:47 pm »
buy another pump of ebay, it is easier and cheaper than buying the repair kit which requires you to dismantle the pump
I changed my pump for a different reason and it is fairly easy to do
btw is your pump a Mk60 or Mk60EC1
Offline marko
« Reply #11 on: December 14, 2013, 12:05:01 am »
thanks alot for advice eddie..
mine is the MK60 model
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
   Component: ESP FRONT MK60      0101
   Revision: 00H11001
   Coding: 0023170
   Shop #: WSC 01279 785 00200
   VCID: 73EFE5F3125EDE802CE
« Last Edit: December 14, 2013, 12:07:37 am by marko »
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
Re: Re: ESP Light permanently on :S
« Reply #12 on: December 14, 2013, 10:04:18 am »
I ended up buying a pump from bba reman. Came with a lifetime warranty and its built with stronger parts.
Sent from my GT-I9300 using Tapatalk 2
Offline marko
« Reply #13 on: December 14, 2013, 10:42:49 am »
Any links raz???
Would being a tdi make any difference??
Offline RetroRaz
  • -Given: 32
  • -Receive: 194
« Reply #14 on: December 14, 2013, 12:23:59 pm »
Don't think so. Mine was a TDI. Just Google up BBA Reman.
