Author Topic: If it's not the DV or the coil packs what is it? - Update and confused!  (Read 25807 times)
Offline E30Dom
  • -Given: 42
  • -Receive: 76
Re: If it's not the DV or the coil packs what is it?
« Reply #15 on: September 29, 2011, 08:29:38 pm »
Had a compression test but as PDT Dave said it needs to be more in depth testing to really make issues apparent  :sad1:
Do get a fluttery boost sound.  Am replacing the n75 valve as matter of course, when I take dipstick out the engine doesnt run like sh*t as expected, in fact there is no change in engine note or hunting....  :sad1:
What happens when you remove the oil cap with engine running?
Diesel Daily Hack.
« Reply #16 on: September 29, 2011, 08:30:31 pm »
2mins will post a vid taken this morning . . .  :happy2:
« Reply #17 on: September 29, 2011, 08:33:31 pm »
Saint Steve
« Reply #18 on: September 29, 2011, 08:43:45 pm »
that's not right at all.. catch can installed , have you tried it without that bsh fitted and going back to a Stock pcv?
« Reply #19 on: September 29, 2011, 08:45:00 pm »
Ordered Rev N kit this morning  :happy2:
Offline Mandy
  • -Given: 95
  • -Receive: 94
« Reply #20 on: September 29, 2011, 08:49:37 pm »
no real fluttery boost sound on mine, more of a 'skip' motion when accelerating, did it on the way home today and definitely worst when in 4th or 5th gear, but flutter/judder/skip would sum it up
I had exact same problem recently, only happened about 2-3 times, randomly. Like you, seems to occur in higher gears, 3-4 or 4-5.
Changed spark plugs and seems ok at the moment. Spark plugs were very loose when I changed them.  :confused:
Also got cam follower change on the 'to do' list.
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #21 on: September 29, 2011, 09:35:11 pm »
[/quote]
Hmmm interesting. Mine has been like this for nearly 2 weeks now and is wrecking the usual smooth ride. Certainly hope it isnt the spark plugs as they replaced those during service a mear 5 months back.
Short of changing  the N75 and the PCV plus hooking it up to a VAGcom im running out of ideas
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #22 on: September 30, 2011, 09:37:18 pm »
Funny, my plugs were changed 5 months back too... Is yours mapped?
Mines back in next week...
Diesel Daily Hack.
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #23 on: October 01, 2011, 01:05:56 pm »
Nope mine is completely standard as far as i am aware. VW changed mine (well they should do as part of main service - havent looked of course), in May and did the coil packs on the recall at the same time. Didnt have any problems the entire previous year since i bought.
« Reply #24 on: October 01, 2011, 01:12:18 pm »
i would check to see if they did change the spark plugs--my guess is on they haven't
« Reply #25 on: October 01, 2011, 01:21:29 pm »
Seat mech swapped plugs and on autobahn it still logged the fault.
Tried new coilpack, still logged logged fault on cyl3.
Fittin REV N PCV as matter of course this week.  My money is on injector & / or dirty valves not seating.  :sick:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #26 on: October 01, 2011, 01:47:18 pm »
I'm not having any faults logged... it just pulses in the higher revs.
Do our cars have vvt? Could it be a sensor for that? But surely that would log something?
Dom
Diesel Daily Hack.
« Reply #27 on: October 01, 2011, 01:55:32 pm »
Dom
Yes, I'm led to believe they do have vvt.
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #28 on: October 01, 2011, 03:43:28 pm »
hi all,
been doing some more research and came across this thread.
It refers to similar items that we have been experiencing and looks at the PCV
After taking my engine cover off and looking at my PCV it has the same issue as in this thread, so a call into the VW stealer on Monday to find out how much the parts are.
http://vagdrivers.net/forums/index.php?showtopic=40537
« Reply #29 on: October 01, 2011, 03:47:47 pm »
I anticipate my new PCV kit comming.
However preparing myself for having to swap injector.  Also have a lambda sensor (Sensor 2, post cat) to replace.
