Author Topic: EVAP emissions control fault - Updated  (Read 11424 times)
Nasir
« on: October 13, 2011, 10:47:45 pm »
Following on from this thread: http://www.mk5golfgti.co.uk/forum/index.php/topic,35998.0.html
These are the fault codes that were found on the car. I've looked them up on Ross tech but are they linked?
Address 01: Engine        Labels:
   Part No SW:    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: --H14---    Serial number:
   Coding: 0403000318070160
   Shop #:
   VCID:
3 Faults Found:
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 - No Signal/Communication - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 4
                    Mileage: 72033 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:15:27
             Freeze Frame:
                    RPM: 1023 /min
                    Load: 14.9 %
                    Speed: 66.0 km/h
                    Temperature: 84.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.351 V
008801 - Boost Pressure Control Valve (N249): Mechanical Malfunction
               P2261 - 008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 6
                    Mileage: 72306 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:15:29
             Freeze Frame:
                    RPM: 2741 /min
                    Load: 12.2 %
                    Speed: 74.0 km/h
                    Temperature: 87.0°C
                    Temperature: 19.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.224 V
001089 - EVAP Emission Control Sys: Incorrect Flow
               P0441 - 002 - Lower Limit Exceeded - MIL ON
             Freeze Frame:
                    Fault Status: 11100010
                    Fault Priority: 0
                    Fault Frequency: 3
                    Mileage: 72789 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 09:30:44
             Freeze Frame:
                    RPM: 833 /min
                    Load: 15.3 %
                    Speed: 0.0 km/h
                    Temperature: 78.0°C
                    Temperature: 22.0°C
                    Voltage: 14.224 V
Readiness: 0000 0000
« Last Edit: November 14, 2011, 06:14:50 pm by Nasir »
Offline mortygttdi
  • -Receive: 146
Re: Fault codes on 2006 GTI
« Reply #1 on: October 14, 2011, 12:59:51 am »
I would say possible that there all related? Looks like the recirc dv has give up the ghost or its on its way out, get it changed clear the faults and keep an eye on the first fault if it persists have cylinder 1 pressure tested?
Darren
Offline andrewparker
  • -Given: 32
  • -Receive: 78
« Reply #2 on: October 14, 2011, 09:00:46 am »
First up, thanks for all your help guys, for me it is invaluable, particularly as none of that stuff makes any sense at all to me!
Darren, are you suggesting an upgrade to the Revision D diverter valve?
  • -Given: 32
  • -Receive: 78
« Reply #3 on: October 14, 2011, 09:04:47 am »
Oh, and just to provide a few more details, prior to the warning the light and following it coming on the car has felt absolutely fine. Since Nasir cleared the warning light I have done about 30 miles and it has not returned.
Offline mortygttdi
  • -Receive: 146
« Reply #4 on: October 14, 2011, 02:39:28 pm »
If its on the ED30 cannot you not take it out and check it? I'm sure its a remote DV i.e easier to get to I presume.
There is air escaping from somewhere and that's the most likely place other than intercooler pipes.
Darren
  • -Given: 32
  • -Receive: 78
« Reply #5 on: October 14, 2011, 03:03:46 pm »
I'm not lucky enough to have an Ed30 dude! I guess it's worth changing anyway and I can do it myself.
The warning light still hasn't came on again however I keep on thinking it feels a bit breathless on part throttle, but that might just because I'm being hyper sensitive knowing that something is wrong.
Offline mortygttdi
  • -Receive: 146
« Reply #6 on: October 14, 2011, 04:16:49 pm »
Sorry don't know where I got Ed30 from, early morning thought malfunction :signLOL: any way if it feels iffy then change it anyway mate you'll probably notice the difference straight away has the power will have been ebbing away ever so slightly over time has the DV breaks down.
Darren
  • -Given: 32
  • -Receive: 78
« Reply #7 on: October 18, 2011, 08:57:32 am »
Well the warning light has returned, time to get it in the garage :sad1:
  • -Given: 32
  • -Receive: 78
« Reply #8 on: October 27, 2011, 08:43:25 am »
So apparently the N80 Solenoid Valve is at fault. Does this sound accurate, and is it easy to replace?
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #9 on: October 27, 2011, 02:11:34 pm »
Evaporative Emission (EVAP)
Canister Purge Regulator
Valve N80
This shows the layout - not sure how easy to change (P10)
http://vw.nate-online.com/techdocs/2.0L%20FSI.pdf
  • -Given: 32
  • -Receive: 78
« Reply #10 on: October 31, 2011, 08:53:01 am »
This problem is really starting to p*ss me off now. Paid over £100 to have the N80 Solenoid Valve changed on Friday and the warning light has popped back on the dash.
Where do I stand with something like this if they've replaced a part that wasn't at fault?
  • -Given: 32
  • -Receive: 78
« Reply #11 on: October 31, 2011, 09:08:17 am »
Just another question, the Boost Pressure Control Valve (N249), this is what is otherwise known as the diverter valve right?
Offline brookesb32
  • -Given: 59
  • -Receive: 75
« Reply #12 on: October 31, 2011, 11:24:38 am »
Yep that is the diverter valve
Offline mortygttdi
  • -Receive: 146
« Reply #13 on: October 31, 2011, 02:59:06 pm »
I don't want to sound rude but I told you in the top post Ive seen this quite a few times and the Diverter Valve should have been your first port of call and probably cheaper.
When the DV breaks up it lets air past the valve where it shouldn't and this is why your getting your evap emissions fault, the bank 1 could just be a spark plug thats not gapped properly.
That does sound arrogant SORRY Andrew :signLOL:
Darren
  • -Given: 32
  • -Receive: 78
« Reply #14 on: October 31, 2011, 03:12:31 pm »
Hey, it doesn't sound arrogant at all Darren. I'm just not too hands on with engine stuff and decided to trust the garage rather than try and fix it myself. My fault I guess.
Just gutted now that I've paid £100 for a fix that wasn't needed, and now it will be more money if it is the DV. :fighting:
