Author Topic: Intercooler hose seal part no required.  (Read 11478 times)
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« on: October 23, 2011, 11:07:02 pm »
When I was changing the wheels on my car today for the winters I noticed there was a bit of oily gunge starting to seep through the join of the undertray and splitter.  The only thing I can think of is either some air con oil or that the inter cooler pipe is leaking slightly.  This being the case I suppose its also leaking a bit of boost...
I didn't have time to take the undertray off or investigate further but does anyone know if there is a seal ring or is it just a clamp thats likely to need cleaning and tightening.  Leak observed just forward of the drivers side wheel arch.
edit:
Anyone got a part no for the seal ring?
« Last Edit: October 23, 2011, 11:23:27 pm by ub7rm »
Sepang Blue S4 BE Avant
Re: Intercooler hose seal
« Reply #1 on: October 23, 2011, 11:09:48 pm »
There is an o ring, mine has perished twice and has felt much better after it was replaced  :happy2:
« Reply #2 on: October 23, 2011, 11:11:03 pm »
Has been drivers side both times on mine however others ar prone to going, Robdf2 has had other ones fail.  Only a cheap fix  :happy2:
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #3 on: October 23, 2011, 11:15:38 pm »
^  Thanks for that.
Any chance of a cheeky part no  :innocent:
« Reply #4 on: October 23, 2011, 11:16:46 pm »
^  Thanks for that.
Not a problem.  I honestly wouldnt know, if you stick a hint to needing p/n in your title im sure someone will be along soon to help  :happy2:
Offline ub7rm
  • -Given: 35
  • -Receive: 43
« Reply #5 on: October 23, 2011, 11:24:47 pm »
^  Thanks for that.
Good plan, cheers dude  :happy2:
Offline micky 32
Re: Intercooler hose seal part no required.
« Reply #6 on: October 24, 2011, 03:47:24 pm »
I have the same problem on the passenger side of the intercooler weeping oil.
2008 Octavia vRS K04'd , Forge twintercooler, Evoms, Autotech uprated pump, full Milltek exhaust 324bhp on JKM's rollers ;-)
Offline QD MBE
  • -Receive: 102
« Reply #7 on: October 24, 2011, 05:05:54 pm »
Drivers side pic.
Offline QD MBE
  • -Receive: 102
« Reply #8 on: October 24, 2011, 05:09:42 pm »
8A (x2) is specified for the Pass side hose.
Don't be fooled by number 3.  It is a Clamp.
« Last Edit: October 24, 2011, 06:52:29 pm by QD »
Offline robdf2
« Reply #9 on: October 24, 2011, 06:05:15 pm »
yep i have , seems my car is always doing weird things lol.
make sure you do get the coreect oring because either end of that pipe are different sizes , i have no idea why they didnt make the o rings a standard size  :stupid:
2008 Chrono yellow Cupra
Offline baldwined30
« Reply #10 on: October 24, 2011, 10:13:35 pm »
Ive got my old pipes if you wanna buy them off me. I swapped mine for the S3.
Ed30
« Reply #11 on: October 24, 2011, 10:29:42 pm »
Question:  would the forge turbo hoses fit to the APR intercooler?
Offline bacillus
  • -Receive: 453
« Reply #12 on: October 24, 2011, 11:01:24 pm »
No, the outlet pipes on the APR IC are larger than the S3 (and standard IC) ones. It comes with it's own bespoke IC hoses.
« Last Edit: October 24, 2011, 11:03:49 pm by bacillus »
« Reply #13 on: October 24, 2011, 11:04:23 pm »
Bugger.  So I wonder if i would be stuffed the the turbo discharge & intercooler pipe too?
Offline bacillus
  • -Receive: 453
« Reply #14 on: October 24, 2011, 11:11:13 pm »
The hoses taper to fit into the standard turbo discharge & throttle body pipe on a standard car so it should work with the "uprated" pipes as well.
