Author Topic: SDS drills  (Read 4230 times)
SDS drills
« on: November 04, 2011, 11:29:57 pm »
Stupid question but can I use an SDS drill for drilling into wood etc? I know they're designed to drill into masonry. Current drill is broken after 20 years of service. I've been advised to go for an SDS one.
Offline andrewparker
  • -Given: 32
  • -Receive: 78
Re: SDS drills
« Reply #1 on: November 05, 2011, 07:06:02 am »
No, get a good combi drill. I have a Makita one which is excellent.
Re: SDS drills
« Reply #2 on: November 05, 2011, 08:32:47 am »
As above. Screwfix were doing the Makita bhp451 I think? For 199 recently. That's a really really good price for a £400 drill. I got one 3 months ago and its awesome!
An sds drill would be useful if you were drilling right thru a wall with like 250ml long drill bit.
That Makita of mine flys thru wall too though
  • -Given: 32
  • -Receive: 78
Re: SDS drills
« Reply #3 on: November 05, 2011, 08:51:20 am »
Mine is still going strong after 4 years. I got it for a similar price but it came in a case with three batteries. They can run down pretty quickly with intensive use, though they do charge quickly. Haven't found a surface yet that it couldn't tackle.
Re: SDS drills
« Reply #4 on: November 05, 2011, 09:48:50 am »
Cool. TBH I need to do some wall drilling. Not much but it's a garage wall. Wanted to do it today hence heading to b&q.
Have masonry drill bits too.
  • -Given: 32
  • -Receive: 78
Re: SDS drills
« Reply #5 on: November 05, 2011, 09:56:50 am »
Seriously, a good combi drill will handle any masonry.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: SDS drills
« Reply #6 on: November 05, 2011, 10:13:42 am »
you can if you use an sds+ adaptor with 13mm chuck
My Bosch Sds+ has quick change chucks :laugh:
Cluster and Key coding
Location Great Yarmouth
Offline RobH
  • Revo stg 2+
Re: SDS drills
« Reply #7 on: November 05, 2011, 10:32:08 am »
Combi drills for drilling into masonary doent make me laugh.
An sds drill with a setting for normal drilling is totaly fine and are more powerfull than a combi.
This drill would be fine for anything round the house you would just need a 13mm chuck for the wood bits.
http://www.screwfix.com/p/makita-hr2470-2-2kg-sds-plus-drill-240v/99908
http://www.screwfix.com/p/makita-keyless-chuck-13mm/38973
That sds would walk all over any combi in any situation aslong as you have mains there thats the only downside.
« Last Edit: November 05, 2011, 10:57:29 am by RobH »
Re: SDS drills
« Reply #8 on: November 05, 2011, 11:34:52 am »
I was looking at the DeWalt D25013K
clicky
And one of these:
clicky
don't trust keyless chucks to be strong enough.
Any remarks on the dewalt?
Offline RobH
  • Revo stg 2+
Re: SDS drills
« Reply #9 on: November 05, 2011, 11:54:17 am »
Dewalt has been going downhill for a while now regarding drills makita and milwaukee are better and thats what id go with.
Keyless chucks are good but if your unsure then get a key chuck personaly i just couldnt be bothered faffing about with one i have never had a problem with the makita keyless chucks tbh.
Re: SDS drills
« Reply #10 on: November 05, 2011, 12:14:41 pm »
I always though dewalt were the "pro" version of B&D, like the difference in blue and green Bosch tools?
Will go for the Makita then.
Offline RobH
  • Revo stg 2+
Re: SDS drills
« Reply #11 on: November 05, 2011, 02:51:31 pm »
They are but their pro version compared to makita or milwaukee is inferior these days.
« Last Edit: November 05, 2011, 03:11:08 pm by RobH »
Offline candy turbo
Re: SDS drills
« Reply #12 on: November 05, 2011, 05:57:17 pm »
if using mains any sds is pretty much the same , cordless for the money makita are good but not the best the batteries have problems and the gear s are not too good , if you want the best cordless drills on the market look at panasonic
Re: SDS drills
« Reply #13 on: November 05, 2011, 06:35:01 pm »
I'm not a huge fan of cordless drills.
Either way, problem solved - borrowed my grandad's corded combi and he's also given me an 18V cordless one he's had laying around. Means I can delay the need for an SDS/combi for now. Given that I have a cordless, I reckon SDS should be able to tackle the heavy duty stuff.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: SDS drills
« Reply #14 on: November 06, 2011, 12:10:02 am »
I find it depends on what tool you buy
