Author Topic: Squeal when moving off\changing gear  (Read 11088 times)
Re: Squeal when moving off\changing gear
« Reply #15 on: November 16, 2011, 04:01:16 pm »
haha, i laugh at that! I have had so many issues with my VW dealer who did the cambelt that there is 99% chance of sweet f a.
Still ill try pull something off, i think i have some credit.
Please tell me they don't have to lift engine up to replace?
lift engine up?  you mean the plastic engine cover? Its quite easily accesible anyhow
It is the one around the alternator, yes  :happy2:
« Reply #16 on: November 16, 2011, 04:01:44 pm »
Where are you based Steve
Offline SteveS
« Reply #17 on: November 16, 2011, 04:30:19 pm »
Watford way, Off junc 21 of M25 or 5 of M1.
I meant the engine, not the cover, to change the cambelt they remove the engine (lift it up)
So the Aux belt is the one round the alternator? Well ill take a look at it as its easy view on the left of engine and see what it looks like..
could any oil help here? I'm guessing not..
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
« Reply #18 on: November 16, 2011, 04:34:03 pm »
They don't remove the engine, its just supported due to having to remove the left engine mount.
The aux belt it the belt you can see on the left of the engine... the cam belt is under a cover so cannot be seen!
« Reply #19 on: November 16, 2011, 04:34:31 pm »
I'm pretty sure if you lubricate it, it will slip and you don't want that!
Water on it can cause it to squeal I think
« Reply #20 on: November 16, 2011, 04:35:22 pm »
Perhaps try and get a video or sound clip?
Offline SteveS
« Reply #21 on: November 16, 2011, 04:38:27 pm »
Right cleared up. I will take a look at it.
Yes that's what i thought we would say about oil.
How hard of a job is this, i wonder if there is a how to somewhere.. hmm
SOLD!! :(
Offline SteveS
« Reply #22 on: November 16, 2011, 04:39:07 pm »
ill try, not sure it will pick it up. its only when moving, so the will probably get engine sound only..
SOLD!! :(
« Reply #23 on: November 16, 2011, 04:51:16 pm »
Just for reference... this is a 2/3 week old aux belt.
Offline SteveS
« Reply #24 on: November 16, 2011, 06:49:44 pm »
Looks pretty clean...
Sounds below and the times you should hear it
4, 11, 16, 20 - http://www.wikiupload.com/H80F9YR8DVKJIHP
1, 7 - http://www.wikiupload.com/32EIYSK4SVXWC4V
Oh and to add, this only happens when changing gear or moving off. Not on idle
« Last Edit: November 16, 2011, 06:55:30 pm by SteveS »
SOLD!! :(
« Reply #25 on: November 16, 2011, 06:52:12 pm »
Permission Denied
This file is private, and you are not authorized to view or download it. This file may be undergoing review for reported copyright infringement.
Why am I seeing this?
This file is private to prevent unauthorized access to it. If this is a mistake, please contact the owner to set the appropriate permissions.
Offline SteveS
« Reply #26 on: November 16, 2011, 06:55:41 pm »
try again
SOLD!! :(
« Reply #27 on: November 16, 2011, 08:52:06 pm »
Looks just as good as mine to be honest.
« Reply #28 on: November 16, 2011, 09:25:09 pm »
Found it hard to tell Chris.
Reminds me that lately Ive had a noise on cold start in line with the revs. Sounds as if a belt could be rubbing on plastic almost.  Im sure its not but its the best way to describe it.  Goes away when warmed up aswell.  Will see if it does it in the morning and get a video.
Offline SteveS
« Reply #29 on: November 16, 2011, 09:28:23 pm »
Chris?
Could you hear it in my sound clips? i could. you need to turn sound up, and bass down if u can. but from my laptop is was easy enough to hear at those seconds mentioned
SOLD!! :(
