Author Topic: Car broke down today - Help needed!  (Read 12445 times)
Offline heavyd
  • -Receive: 29
Re: Car broke down today - Help needed!
« Reply #15 on: November 11, 2011, 06:10:45 pm »
Well i fitted a new pressure sensor, cam follower and fuel filter on order. If I replace all three, hopefully problem will be sorted!
« Reply #16 on: November 11, 2011, 06:13:37 pm »
fingers,toes crossed this is the end of the problems Dom
Offline heavyd
  • -Receive: 29
« Reply #17 on: November 12, 2011, 09:38:01 am »
I hope so :sad1:
Well it wasn't the sensor, car died again this morning :confused:
« Reply #18 on: November 12, 2011, 10:22:09 am »
bloody cars--when i get mine back thinking bout selling it and getting a mk4 r32 i have seen
Offline martziniuk
« Reply #19 on: November 12, 2011, 11:15:47 am »
I hope so :sad1:
Wow you car really is something else  :sad1:
By the codes it looked certain to be the sensor.
Mk2 Octavia vRS with K04 conversion, 3"TBE & Decat, APR HPFP, BDM Intake, S3 I/C, Sachs clutch & Unicorn custom map, S3 brakes, AP coilovers, THS mounts.
B8.5 Audi S4 with uprated pulley and unicorn Stage 2
« Reply #20 on: November 12, 2011, 10:54:09 pm »
Can you do a check on the in-tank pump?
It may have a fault on that which could be causing your low fuel pressure issue?
Offline bacillus
  • -Receive: 451
« Reply #21 on: November 12, 2011, 11:14:21 pm »
Yup, log block 103. Reference value should be around 5 bar although mine is around 4.5 bar at red line but with no ill effects.
Offline heavyd
  • -Receive: 29
« Reply #22 on: November 13, 2011, 04:11:18 pm »
I did some logs and the intank pump pressure is fine, I ran basic settings on it aswell.
Hopefully its the fuel filter when it arrives tuesday
My luck struck again at the tyre fitters yesterday, they managed to put the tyres inside out after they balanced them(Vredesteins) then when they refitted them and balanced them again, they managed to chip an inch of paint off the rim with the tyre iron :fighting:
 :sad1: :sad1: :sad1:
« Reply #23 on: November 13, 2011, 10:21:41 pm »
Bit of a drive but you should of came to me Dom,I would of fitted your tyres with out catching your alloys
Offline PDT
  • -Receive: 142
« Reply #24 on: November 14, 2011, 09:47:02 pm »
Get them to pay for a refurb.
Offline heavyd
  • -Receive: 29
« Reply #25 on: November 17, 2011, 02:38:53 pm »
Oh well, cam follower, fuel filter were changed, I stuck a remap on aswell just incase it was the shark stock map at fault.
I did some datalogging when I got a few fuel cuts. Think I've narrowed it down to the in tank fuel pump, logs below are quite bad to be honest, first column is the intank fuel pressure, the high pressure logs show practically no fuel at all getting through at points, and I deleted a fair few columns out of the graph aswell. Also still have that massive boost spike, even with the new n75 valve fitted, repair bill now stands at over £3800. milltek downpipe has been sent to milltek for repair, as the machine shop couldnt machine the flange back it was that badly distorted off the bloke that welded it up for me. So no doubt the milltek bill will be pushing the repair bill to close to £4000 :surprised:
Offline vag12
« Reply #26 on: December 13, 2012, 06:06:35 pm »
Did you sort out the problem in the end?
Offline bacillus
  • -Receive: 451
« Reply #27 on: December 13, 2012, 08:12:26 pm »
Yes he did...
Offline heavyd
  • -Receive: 29
« Reply #28 on: December 14, 2012, 02:21:26 am »
It was the intank pump that caused the problem :happy2:
Offline E30Dom
  • -Given: 42
  • -Receive: 76
« Reply #29 on: December 14, 2012, 11:33:29 am »
Did you replace for oem? Is there an uprated one and would it make any difference if there was...?
Diesel Daily Hack.
