December 19, 2025, 09:50:42 pm
General
Detailing
Wheels sealed - same old wash routine afterwards?
Topic: Wheels sealed - same old wash routine afterwards? (Read 1565 times)
AndyED30
Always Involved
-Given: 3
-Receive: 11
ED30
November 20, 2011, 07:01:49 pm »
I've just given my wheels x3 coats of poorboys plus one coat of Dodo PH.
Next time I wash the wheels can i carry on using an EZ brush/Bilberry and normal routine or will this break down the sealant?
I only dilute 1/10 for the Bilberry anyway so if I'm careful with the brush is this ok? I only ask because the wheels/arches/calipers etc took AGES and I'm not doing that again for a while
Cheers, Andy.
stealthwolf
Just look at my post count
-Given: 306
-Receive: 292
ED30 No.1412
Re: Wheels sealed - same old wash routine afterwards?
Reply #1 on:
November 20, 2011, 07:10:45 pm »
If you've adequately sealed the wheels, then a simple rinse/powerrinse will be enough.
If you need to shift some more dirt, then use a wash mitt and shampoo.
The
GTI
isn't just a machine. It's very much a living, breathing thing.
Greeners
-Given: 201
-Receive: 199
Reply #2 on:
November 20, 2011, 07:14:27 pm »
Yes was about to say the same as Stealth, just the good old Power washer and a soft mitt should be more than enough!
As long as you don't leave it 3 months that is!
AndyED30
Always Involved
-Given: 3
-Receive: 11
ED30
Reply #3 on:
November 20, 2011, 07:28:19 pm »
Cheers Stealth, that sounds good to me.
Don't worry Nathan it gets washed every weekend mate................without fail
JackG
-Given: 33
-Receive: 31
aint nuttin to it but to do it.
Reply #4 on:
November 26, 2011, 08:43:38 pm »
As above, power wash should help move alot of the brake dust
Use a brush to help agitate if it's not all moving...or even a very light mixture of wheel gel to aid the removal without damaging the wheel surface too much
www.distinctdetailing.co.uk
General
Detailing
