Author Topic: Car keeps cutting out :(  (Read 9438 times)
Offline keano
  • -Given: 79
Re: Car keeps cutting out :(
« Reply #15 on: November 26, 2011, 10:45:25 am »
Hi Dave,
Thanks for contacting your friend for me.
The car usually cuts out when coming to a stop. But when cold this morning, it cut out about 1,500 revs.
It's pointing towards fuel pressure I guess, but it's very coincidental that it happened after my coilovers been fitted  :confused: :chicken:
Offline PDT
  • -Receive: 142
« Reply #16 on: November 26, 2011, 10:57:41 am »
give it a good look over around the areas where they would have been working when fitting the coilovers, personally cant think of anything that would connect the 2 things.
does it smoothly cut out as in the revs slowly drop and cuts out or does it stutter and choke a bit?
Offline keano
  • -Given: 79
« Reply #17 on: November 26, 2011, 11:00:46 am »
Lovely and smooth haha. It jerks abit when you try and catch it before it cuts out if you get me? But it's usually very smooth.
Offline keano
  • -Given: 79
« Reply #18 on: November 26, 2011, 03:28:26 pm »
 :sad1:
Offline keano
  • -Given: 79
« Reply #19 on: November 27, 2011, 10:11:26 pm »
Since the bad day she had Friday I left her on the drive over the weekend.
Went out in it tonight to see if things had changed. I had one loud missfire/pop (like a skyline gtr lol)  and everything seems fine now.
Infact, it's the best it's ever driven. I went through a few heat cycles and turned it on and off a few times and everything seems okay.... Hmmm   :stupid:
Offline gulfstream11
« Reply #20 on: November 28, 2011, 12:46:23 pm »
Good... Cos you looked pants in you're mums Volvo... :signLOL:
Offline keano
  • -Given: 79
« Reply #21 on: November 28, 2011, 05:11:56 pm »
Update:
Vagcom showed intermittent errors with high and low fuel pressures.  :stupid:
Following VCDS's recommendations and that of VagCo, we've ordered a new 'low pressure fuel sensor' for the fuel pump.
This should sort the problems out...
Offline RobH
  • Revo stg 2+
« Reply #22 on: November 28, 2011, 05:23:10 pm »
Mine used to do this it was the dv is your a forge one by any chance as they stick and it causes the car to randomly stall when stopping intermitently.
Offline keano
  • -Given: 79
« Reply #23 on: November 28, 2011, 05:24:18 pm »
It's a new revision D mate.  :sad1:
Offline RobH
  • Revo stg 2+
« Reply #24 on: November 28, 2011, 05:27:18 pm »
Just make sure the sensor is clipped on the dv correctly failing that ive no idea.
Offline Dannyboy88
« Reply #25 on: November 28, 2011, 05:46:25 pm »
Sorry i could get your car scanned over the weekend mate, trust my friend to be away lol :-( but if anyone in the south yorkshire area needs a Vagcom scan contact me and i'll let my friend know :-) his prices are cheap
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=jiq8pmo9vfttetciu7pv7c6n5q&/topic,19740.0.html
« Reply #26 on: November 28, 2011, 07:00:06 pm »
Keano. If you want to borrow my VCDS cable for logging etc. just let me know. I'll send it up to you and you can drop it off at my parents. :-)
Offline keano
  • -Given: 79
« Reply #27 on: November 28, 2011, 07:50:21 pm »
Cheers Richy!  :drinking:  :love:
« Reply #28 on: November 28, 2011, 08:23:31 pm »
Hope it's sorted Nick  :sad1:  Can borrow my cable as of 12Dec
Offline Boothy
  • All donations accepted, thanks.
« Reply #29 on: November 28, 2011, 08:31:38 pm »
That is EXACTLY what happened to mine. VW told me that it was the cam follower and the HPFP however the local specialist said it was the low fuel pressure sensor mounted near the front of the engine. That was a £50 part plus fitting. I did check the came follower my self too.
