Author Topic: Attenzione - My MFD2 has changed itself to Italian!  (Read 1495 times)
Offline cartwheel
« on: December 03, 2011, 01:55:00 am »
Basically...what it says in the title! Any ideas? How do I change it back?
Cartwheel
Offline bobsgolf
Re: Attenzione - My MFD2 has changed itself to Italian!
« Reply #1 on: December 10, 2011, 03:56:27 pm »
afternoon
Press the info button ( to the right of the  volume button ) and your screen should look like the picture above
Now press the button which is level with the words syst. settings ( the second button up from the volume button , the first button is the balance & treble settings button ( a picture of a music note ) and you will get a screen like above , and then press the 6th button up from the volume button . This is the language setting button , you will then get another screen which lists all languages , all you need to do I select , the language you want and whither its imperial or metric measurements i.e. miles per hr. or kilometres'
I hope this resolves your problem
Any questions you can give me a shout
Bobsgolf
Bobsgolf
Offline bobsgolf
« Reply #2 on: December 10, 2011, 04:53:02 pm »
[/img]
  this should be photo 1
img]
and this should be photo 2
if i have got the photo posting right
Bobsgolf
Offline bobsgolf
« Reply #3 on: December 10, 2011, 04:58:25 pm »
[/img]
[/img]
Bobsgolf
Offline bobsgolf
« Reply #4 on: December 10, 2011, 05:02:22 pm »
Bobsgolf
Offline cartwheel
« Reply #5 on: December 12, 2011, 04:41:44 am »
Perfect!! Cheers bobsgolf.
God knows why it changed, maybe I'll brush up on my Italian incase it goes again!
Ciao.
