Author Topic: Badge replacement  (Read 2381 times)
Offline Sug
Badge replacement
« on: December 10, 2011, 07:12:55 pm »
I know this will have been posted before but cant seem to find it, I am wanting to replace the VW badges on my car. front seems easy enough either prise off or remove grill???? As for the back???? :confused:
EDITION 30 GONE, MK6 R GONE........AUDI 8V S3.....Stock for now
Re: Badge replacement
« Reply #1 on: December 10, 2011, 09:14:10 pm »
Back depends on what year the car is but will likely involve removing the whole mechanism.
Offline Sug
« Reply #2 on: December 10, 2011, 09:20:57 pm »
Its a 2008 fella  :happy2:
« Reply #3 on: December 11, 2011, 12:44:28 am »
Might be able to prise off the metal VW bit on the rear badge.
Offline nathangallo
« Reply #4 on: December 11, 2011, 05:20:45 pm »
how did you get the front one off fella is it just simply prising it away, it seems that way ?
« Last Edit: December 11, 2011, 05:30:02 pm by nathangallo »
« Reply #5 on: December 11, 2011, 06:23:53 pm »
The front VW badge can be removed by pushing it in and turning it (can't remember if clockwise/anticlockwise) but this has a good chance of breaking the clips. Better to remove the grille (two screws at top, two under where number plate plinth is) and then undo it from behind.
Offline Sug
« Reply #6 on: December 11, 2011, 07:25:03 pm »
Yeh just push in and turn anti clockwise and it pulls out. be carefull not to break one of the three clips. I broke one but it still went back on fine. The back is a bit more tricky.
 Remove the 2 screws in internal tailgate cover and pull very firmly to remove. (use an window scraper or similar to lever it if need be) then
Remove the connector block and the 3 Torx screws securing boot handle. (you may need to loosen the wiper motor to get to the bottom screw)
Offline nathangallo
« Reply #7 on: December 11, 2011, 07:39:52 pm »
may just take the gamble by twisting!
if not isnt it the torx on the top ? in the bonnet?
Offline Sug
« Reply #8 on: December 11, 2011, 08:20:23 pm »
Think there is also 2 under number plate aswel
« Reply #9 on: December 11, 2011, 08:26:17 pm »
As I said, two at the top and two under the number plate plinth. All torx I think.
