Author Topic: Info about the VAG 130PD engine?  (Read 1281 times)
Offline gazbutS3
« on: December 20, 2011, 11:03:51 pm »
Does anybody have any links to decent info/forums etc for the 130PD engine in the mk4's etc, runnin a Bora as a daily and doing a bit of research because I like to know how things work :smiley:  :happy2:
Offline PDT
  • -Receive: 142
Re: Info about the VAG 130PD engine?
« Reply #1 on: December 20, 2011, 11:15:35 pm »
Heres a bit about the pumpe Duse (pd) injector system, its a good place to start.
http://en.wikipedia.org/wiki/Unit_Injector
Offline PDT
  • -Receive: 142
« Reply #2 on: December 20, 2011, 11:18:04 pm »
Check out 'freds tdi page' its mainly an american site but lots of good info on there.
I would start with altering the breather hose from the cam cover to vent to atmosphere or a catch can and blanking the EGR valve. Give the boost system a good clean out including the inlet manifold and replace the seals.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=gbomjk6qpck5e35s26i0o2tddv&/topic,19740.0.html
« Reply #3 on: December 20, 2011, 11:19:41 pm »
What do you want to know? All the 1.9TDIs are essentially the same lump with different bolt ons.
Offline gazbutS3
« Reply #4 on: December 20, 2011, 11:32:07 pm »
The EGR issue for one, is it best to blank or is periodic cleaning ok etc. Can't fault the Bora TBH, although I do have a vibration/resonance at 2000-2300rpm which is 70-75mph in 6th which bugs me and I'd like to fix, its really smooth at 70 and again at 80 on my private runway, but at these rpms I can feel it in all gears. And the temptation for a cheeky map in the new year is obvious, so want to know the best route there too :happy2:
« Reply #5 on: December 20, 2011, 11:42:39 pm »
Best to get a straight thru EGR delete pipe, similar to below.
If you intend to map it, I would get rid of the cat, ad replace it with a decat... then map it. The 130PD was a good choice, the 150PD are known for spitting out cam followers.... you should be able to get 170-180bhp out of the 130PD.
Offline gazbutS3
« Reply #6 on: December 20, 2011, 11:45:20 pm »
 :happy2: thanx will do
Offline Shorty
  • -Receive: 24
« Reply #7 on: December 21, 2011, 08:50:13 am »
I run a PD130 Bora as a daily too Gaz, proper good runners I think!
Mines remapped with an EGR delete and I've smashed the cat out too, it goes alright and obviously mega on fuel!
| Mk7 R |
Offline PDT
  • -Receive: 142
« Reply #8 on: December 21, 2011, 01:44:00 pm »
Vibration is likely to be flywheel.
