hi guys know it sounds silly but dont want to brake anything in the process. as want to spray it satin black.
Aled
Easiest way is to remove the front grill from the car so you can get to the clips at the back of the badge.
Lift the bonnet and remove the 2 torx screw either side of the slam panel and release the 2 clips on the outer edge of the grill, then remove the 2 philips screws from underneath the numberplate plinth in the top of the lower mesh grill and lift the front grill from the car. reverse to put it back on the car
Dave
