Author Topic: Halfords 5-piece Lifting Kit  (Read 6193 times)
« on: April 26, 2009, 07:01:16 pm »
Halfords 5 Piece Lifting Kit
Cost: £69.99 (cheaper if you have a trade card)
Why
Trolley jack is useful for lifting the car without breaking your back. Axle stands give the car a bit of support whilst you work under it. The car creeper makes it easier to move in/out from underneath the car. It also makes you look like a proper mechanic. Wheel chocks help to stop the car rolling when you jack it up. Not sure what the "lug wrench adaptors" are for.
Sourcing
Halfords. clicky
Assembly
Not much required apart from the creeper, which wasn't difficult.
Usage
The trolley jack does a marvellous job of lifting the car up. The wheel chocks are metal, hinged and have a metal stand that makes sure they're triangular when in use, folds flat(tish) when not. The axle supports have three height settings and seem to support the car (only tried it briefly though). The car creeper is okay, managed to support my weight!
Plus Points
  • £10-20 cheaper than buying the items separately.
  • Trolley jack is sturdy and lifts the car without problems.
Minus Points
  • Paint chips off all tools readily
  • Wheel chocks are designed for smaller tyres (15" and below according to the instructions!)
  • Axle stands have fixed height settings
  • Car creeper isn't much use unless the car is raised particularly high.
Summary
Save your money. Buy the trolley jack separately. Get wheel chocks from elsewhere (Halfords supply only plastic ones separately). Get better rated, adjustable axle stands. Or better still, have a garage with a hydraulic lift!
Offline WhiteGTI
  • F-A-S-T
Re: Halfords 5-piece Lifting Kit
« Reply #1 on: April 26, 2009, 09:05:27 pm »
Good write-up!  :happy2:
Have you got any pics of you using the equipment on your car?
2006 E46 BMW M3 - 343hp
« Reply #2 on: April 27, 2009, 06:32:38 pm »
D'oh! No, but I can take pics of the equipment if needs be. When I swap the wheels over (again!), I'll try and remember to take some pics.
