December 20, 2025, 01:44:47 am
General
Random Chat
Key programming help - Seat Altea
Topic: Key programming help - Seat Altea (Read 7038 times)
skard
Just look at my post count
-Given: 5
-Receive: 245
My Ride:
February 11, 2012, 10:02:48 pm »
Wondering if anyone can assist, as I'm losing the head trying to program a virgin transponder to our Altea. The seller has even sent me a second chip to ensure the first isn't dodgy. The Altea is electrically very similar to the mk5.
Basically, I have one full RCL key and although the car came with a non-RCL key - I broke the capsule chip trying to remove it. Thus I one have one engine starting key now.
It's an 03/2007 car. I have extracted the SKC through Commander and this lets me log into adaptation. Even using the key matching on that software doesn't work.
I am following the Ross-Tech key matching process (or at least I think I am) but the immo just doesn't seem to go into an adaptation mode (the key diagram never shows on cluster).
Thinking our Altea has the newer immo system(like a Golf with xx3/xx4 clusters) , this should not matter as I have the SKC?
Was wondering if there's anything I'm missing - such as ignition having to be on for X amount of time beforehand?
Any ideas would be appreciated.
skard
-Given: 5
-Receive: 245
My Ride:
Re: Key programming help - Seat Altea
Reply #1 on:
February 12, 2012, 10:41:43 am »
Here is a screenshot within 25-Immo, measuring blocks when using a key with a virgin chip...
I take it the Megamos transponder is the right type (key status ok - yes)?
What about Immo (LED) status down bottom right...I notice when I go into adaptation and 000 to clear all keys, this does a countdown every minute. It also shows Safe5 on the cluster display. Does that have any significance? I've waited on it going down to 0 but still doesn't want to adapt.
Like I mentioned, the car has pretty much all Golf mk5 modules in it so anyone who's programmed their own key with a SKC - your input is appreciated.
skard
-Given: 5
-Receive: 245
My Ride:
Reply #2 on:
February 12, 2012, 04:10:39 pm »
No-one ever programmed a key?
Creatz
Always Involved
-Given: 0
-Receive: 15
The Noob
Reply #3 on:
February 12, 2012, 04:17:43 pm »
I needed a New key for my GTI, and was told the coding is so encrypted it has to be done
by VW software,not VCDS dont know how true or if its just the GTI, but either way i dont have VCDS
so i had to get VW to do it
skard
-Given: 5
-Receive: 245
My Ride:
Reply #4 on:
February 12, 2012, 04:20:36 pm »
Because I have the SKC it should be possible (as I can access the immobiliser with it), there must be a step I'm doing wrong, or the guy has sent me two wrong transponders...
Creatz
Always Involved
-Given: 0
-Receive: 15
The Noob
Reply #5 on:
February 12, 2012, 04:54:14 pm »
i thought for none GTI there was a way to place in the ignition and press the buttons and do a sequence to code it.
Eddie-NL
Trader - 2014
-Given: 0
-Receive: 298
My Ride:
Reply #6 on:
February 12, 2012, 05:47:49 pm »
have you got full access to the SEAT cluster with your clone VAG-commander?
by full access I mean
change mileage, read and save immo dump
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
skard
-Given: 5
-Receive: 245
My Ride:
Reply #7 on:
February 12, 2012, 06:20:55 pm »
Yes Ed, made a backup of immo info when I was in, and can load up mileage etc.
Eddie-NL
Trader - 2014
-Given: 0
-Receive: 298
My Ride:
Reply #8 on:
February 12, 2012, 06:29:33 pm »
I take you have a wsc and importer number set in vag-com?
Are you using this
http://wiki.ross-tech.com/wiki/index.php/Immobilizer_IV_Key_Matching
skard
-Given: 5
-Receive: 245
My Ride:
Reply #9 on:
February 12, 2012, 06:37:20 pm »
Where do I input that? Yes using that guide.
Cheers for the help
Eddie-NL
Trader - 2014
-Given: 0
-Receive: 298
My Ride:
Reply #10 on:
February 12, 2012, 06:41:44 pm »
have a look at one of the control modules in the car
ddress 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 962 G
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0003403
Shop #: WSC
01215 210 75981
VCID: 2F691568C78D
No fault code found.
The 01215 is the workshop code 210 is the importer number and 75981 is the job number
If you start vag-com on the interface tab there is an option to enter / set a workshop code
skard
-Given: 5
-Receive: 245
My Ride:
Reply #11 on:
February 12, 2012, 06:43:14 pm »
Will go try it in a mo, hopefully this is the missing link
skard
-Given: 5
-Receive: 245
My Ride:
Reply #12 on:
February 12, 2012, 07:04:32 pm »
Just tried that, got further, but when I put the amount of new keys, at either 2 or 3, the display shows 1-2, or 1-3 and then shows SAFE once moving on from the original key.
Has it got something to do with these chips needing to be pre-coded?
Last Edit: February 12, 2012, 07:16:30 pm by skard
skard
-Given: 5
-Receive: 245
My Ride:
Reply #13 on:
February 12, 2012, 07:48:22 pm »
Thanks Ed that was the missing link in the procedure, I can remove/reinstate my original key, but the new chips just won't take being written to, so it seems.
Is it possible by trying to adapt it while not using the WSC that I could have written false data to it?
However, in measuring blocks it still shows Transponder Lock - NO so I may have just answered my own question!
Last Edit: February 12, 2012, 10:56:50 pm by skard
General
Random Chat
