Author Topic: window problem...  (Read 15798 times)
Offline Rhino
window problem...
« on: February 17, 2012, 11:01:28 pm »
dunno if  anyone else has had this problem....
if i undo  front windows a little bit, then try do them up they end up automatically going down on there own. then have to keep finger on button to make them go backup.
Offline swedishfireball
Re: window problem...
« Reply #1 on: February 17, 2012, 11:06:48 pm »
Had this a bit recently too! Also had it where it won't go anymore than half way down when I was in a drive-thru  :ashamed:
Offline Rhino
« Reply #2 on: February 17, 2012, 11:13:55 pm »
slightly annoying when its cold or ur going down the motorway.
must be a fault somewhere
anyone know how to fix?
Offline Aweful_Truth
« Reply #3 on: February 18, 2012, 12:54:45 am »
have you tried resetting them? disconnect the battery and then reconnect, then reset them by holding all the way down until you hear a click and then all the way up until a click, then they should have auto up and down again? work for mine when they were playing up a while ago
To Bad, So Sad, Bye Bye!
Offline AjayB
  • Golf GT TDI
« Reply #4 on: February 18, 2012, 01:07:43 am »
This happens to my Golf all the time too.. it was just my drivers side but not the passenger side does it too.. So annoying when i need to close the window quickly and it goes down :( It did it on my Dads 2006 Passat also.. common fault on VW? Sometimes my passenger door doesnt unlock with the rest of the doors too which is also so annoying as i have lock and unlock again or use the button on drivers door to let a passenger in the front!! Grr!
Build: http://www.mk5golfgti.co.uk/forum/index.php/topic,40699.0.html
Golf MK5 GT TDI | 35mm H&R Springs | Silver Cabon Fibre Inlays | 20% Rear Tints | Backbox Delete- Dual Tips | GTI Rear Valance
To Do: RNS/RCD510 | FBSW | Black BBS CH 18"
Offline mb
  • -Receive: 29
« Reply #5 on: February 18, 2012, 02:51:29 am »
This sorted mine but I didn't disconnect the battery.  I didn't hear any clicking but held the switch in each position for about 3 seconds after it was all the way up or down
Offline Rhino
« Reply #6 on: February 18, 2012, 12:18:41 pm »
i didnt even know ya could reset them! will give this a try now
Offline AjayB
  • Golf GT TDI
« Reply #7 on: February 18, 2012, 01:37:04 pm »
I'll also give this a go and see if it rectifies my windows going crazy. Is there any reset procedure for the door looks?
« Reply #8 on: February 18, 2012, 05:18:40 pm »
Nope everything else will work fine just as it used to, it's only the windows that get thier memory reset
Offline Rhino
« Reply #9 on: February 18, 2012, 06:24:54 pm »
naaa didnt work for me :(
piece of s.hit!
« Reply #10 on: February 18, 2012, 06:59:39 pm »
 :sad1: I personally have no more suggestions :(
Offline mb
  • -Receive: 29
« Reply #11 on: February 18, 2012, 10:49:56 pm »
There is also something in the manual about resetting the one touch opening & closing which cured my windows for a while.
'Close all windows & doors. Lock the door with the key & hold in lock position for at least 1 second'
Might be useful?!
Offline jonm
    • Staffs-VW
« Reply #12 on: February 20, 2012, 09:38:22 am »
had this since I got the car over a year ago, tried all the known fixes.... een the service dept couldn't fix it..
MPS
« Reply #13 on: February 20, 2012, 03:40:02 pm »
I think this might be a fault with the window regulator. It might throw up a code on VCDS too
Offline Rhino
« Reply #14 on: February 20, 2012, 03:49:55 pm »
is it a big job changing the window regulator?
