Author Topic: rear brake bias with 310s.  (Read 1211 times)
Offline jimk04
« on: February 29, 2012, 06:52:46 am »
When swapping to big rears on a gti is the brake bias ok.?
What about when combined with nqsbbk up front or similar?
Is the bias adjustable within vcds?
Milltek tbe, Forge intercooler, AMD map, Eibach Sportlines, Porsche 996 over AMG 330mm homegrown BBK
Offline Bikerz
Re: rear brake bias with 310s.
« Reply #1 on: March 03, 2012, 09:48:13 pm »
The way ive seen all vag cars including mk4 is a bias valve so will be fine as works off weight transfer giving suspension moment on rear. Ive guess mk5 was same.
Offline jimk04
« Reply #2 on: March 03, 2012, 11:04:18 pm »
no I think the mk5 bias is all done via the abs system and the software in the controller.
Offline blackmagic20vt
« Reply #3 on: March 16, 2012, 10:30:46 pm »
What front brakes you going for and what power you running?
Offline jimk04
« Reply #4 on: March 23, 2012, 10:35:55 pm »
330mm with 996 front calipers and 260hp.
