Right... I'd better contribute, seeing as I was one of the main reasons this started up! (apologies again for going off topic in the other thread
At the moment, I have taken off the plinth (thank god, it looked so damn ugly and ruined the curvature of the front of the car) and just screwed my original number plate back into the screw holes that it was in originally (the screws went through both the plinth and the front mask)
I have got a sticker numberplate that I just haven't got round to putting on yet. Unfortunately it is non-reflective, but thats the risk I'm taking. However, the letters are legal (font, size and spacing)
I really want to give the car the same look as the USA GTI, it looks so much better without a plate - as I'm sure you are all aware. So that means freeing up the glossy black part of the front of the car.
I tried mounting the plate with some plasterboard clips through the bottom grille, so that it hangs down onto the lower valance, but it really looked like the car was sticking out its two front teeth!! Also, mounting it through the lower grille (I think someone on this forum has done that), will surely considerably inhibit airflow to the intercooler!
As UKDUB mentioned below, the Alfa look is certainly one way to explore - i.e. putting the plate underneath one of the headlights (providing you dont have headlamp washers!!!!). With a sticker numberplate it is a challenge to stick it on without making it look angled or squewiff! This is because it follows the contours of the car so much. I think I was experimenting for about 45 mins and only once got it angled correctly!
One other suggestion is one of those pop-up plate holders such as this:
http://www.swiftmotorsports.com/product_info.php?cPath=2049&products_id=3144&osCsid=ffd98cfad50ebf5daea5b033163So I would guess that you mount it underneath the lower valance and have it so it pops up infront of the grille - but will this inhibit air flow to the intercooler?! I have recently wondered if you could put it to the side a bit, so that maybe it pops up over one of the foglight grilles...something to think about and discuss maybe.
What are your thoughts?
