Has anyone got any experience of painting the surface of the brake disc?
This is a serious question. In spite of it first appearing like a joke.
![Tongue :P](https://www.mk5golfgti.co.uk/forum/Smileys/newsmileys/tongue.gif)
Some manufacturers are painting the surface of the brakes, which is then worn off by the pads on first use. This is so that everywhere other than the contact point of the pads is protected against corrosion.
Now, im having my BBK fitted on Saturday, and as yet, i havent gotten round to painting the centers. The pad sweep will miss the very center by around 10mm, so i am left with a quandry. I dont have a circle cutter or anything suitable to mask off the contact patch on the disc for painting.
Has anyone ever adopted the method undertaken by some disc manufacturers now to protect the disc from corrosion by painting the whole surface OR at least as close to the center as possible, leaving the pads to wear off anything else?
