Author Topic: Clutch master cylinder p/n?  (Read 4362 times)
Offline damoegan
« on: March 18, 2012, 09:07:57 pm »
Looking for the p/n of the clutch master cylinder for GTI/ED30 please  :happy2:
Re: Clutch master cylinder p/n?
« Reply #1 on: March 18, 2012, 09:18:57 pm »
A couple of people said new MC didn't fix the sticking pedal Damo  :sad1:
Offline damoegan
« Reply #2 on: March 18, 2012, 09:20:56 pm »
I hope it works for me, Mike  :sad1:
« Reply #3 on: March 18, 2012, 09:39:15 pm »
Me too! Saw that thread you resurrected, I didn't even remember having that issue till I saw that
Offline vRSAlex
  • -Receive: 253
« Reply #4 on: March 18, 2012, 09:47:28 pm »
Could you see any fluid under the car?
Follow AKS tuning on Facebook
Offline damoegan
« Reply #5 on: March 18, 2012, 09:51:45 pm »
Yes Alex, but the master cylinder feels dry....
Think I need to get it up in the air and get the under try off!!
Looks like p/n is: 1K0 721 388 AB..
« Reply #6 on: March 18, 2012, 09:54:05 pm »
That drive shaft oil seal has been leaking for a while please could you check the fluid level Alex?  :notworthy: :notworthy:
Offline vRSAlex
  • -Receive: 253
« Reply #7 on: March 19, 2012, 07:40:54 am »
I will be draining and refilling the box when it gets stripped so you will have brand new fully topped up box oil  :happy2:
Offline GLIDN
« Reply #8 on: March 19, 2012, 08:18:40 am »
 i'm guessing the sticky pedal feeling you referring to, is the fact that you can feel the clutch pedal has no feedback when the pedal returns and sometimes struggles to select gear with clutch in?
Do the MK5 also have the failing master cylinder or cylinder pulling thru the firewall issue as previous generations?
Hmm, this seems like it could fit the bill on my car too.
« Reply #9 on: March 19, 2012, 08:26:28 am »
I think he means the pedal sticks down and you have to pull the pedal back up by putting your foot on the underside I the pedal and giving it a nudge back up  :scared:
Offline GLIDN
« Reply #10 on: March 19, 2012, 08:30:26 am »
Thanks for that, guess I will have to figure out my problem then.
« Reply #11 on: March 19, 2012, 08:36:23 am »
Hope you get to the bottom of it soon
Some info may be in here
http://www.mk5golfgti.co.uk/forum/index.php/topic,13766.msg210439.html#msg210439
Offline Dario
  • booosting... :)
« Reply #12 on: March 20, 2012, 01:18:38 am »
had problems with my pedal also ,but remove the little bug under the clutch cilinder ,it controls the pressure or something like that ,had mine removed ,and presto no pedal problems ,but the pedal is 10-15% stiffer
REVO ST2+ Edition30 -sold
soon 2015 Golf R :)
Offline damoegan
« Reply #13 on: March 20, 2012, 06:56:00 pm »
Any pics of said item, Dario? Even ETKA pics would do  :happy2:
Offline Dario
  • booosting... :)
« Reply #14 on: March 21, 2012, 02:01:31 am »
dont have ,was done at vw shop,so didnt ask any Qs ,will ask them next time what its called and where is it lovated exactly
soon 2015 Golf R :)
