Author Topic: Wheels rubbing on Monza II with spacers & NQSBBK...  (Read 3199 times)
Offline berg
  • -Given: 49
  • -Receive: 38
« on: March 21, 2012, 10:28:29 pm »
As above, when i hit an uneven patch of road/bump in the road my wheels catch as the H & R spacers needed to clear the Porsche calipers mean the Monza's stick out more, does this happen to everyone else who runs the NQSBBK with 18 inch Monza's?
My winter wheels the Skoda Zenith II clear without the need for spacers, and at the moment it puts you off pushing on when you hear the scraping noise.
I presume there is no solution other than running different wheels eg BBS VZ/Pescara?
Thanks.
« Last Edit: March 21, 2012, 10:30:44 pm by berg »
Offline Phil Miller
  • -Given: 86
Re: Wheels rubbing on Monza II with spacers & NQSBBK...
« Reply #1 on: March 21, 2012, 10:32:48 pm »
have you taken the torx head screw out of the arch liner at the top?
2004 Golf 5dr TDI, 140 remap, GTI front bumper, skirts, highline cluster, 18in wheels, jamax coilovers, winter pack
WANTED HIGHLINE CCM AND CECM PLEASE PM ME IF YOU CAN HELP
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #2 on: March 21, 2012, 10:38:14 pm »
hi phil, i have not sir.
now you mention it, i do remember reading something about that somewhere.
so will that remove the liner and therefore the rubbing?
Offline Phil Miller
  • -Given: 86
« Reply #3 on: March 21, 2012, 10:40:37 pm »
well when i first lowered mine on coilovers if i gave it the beans it rubbed slightly i saw the thread about the screw and when i fitted new tyres in jan to my 18in monza reps i took the screw out and TBH i havent heard it rub since mate
Hope it helps mate :happy2:
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #5 on: March 21, 2012, 10:45:52 pm »
What size spacers are they?
I ran 10mm H&R spacers on the front with monzas for a couple of years with no problems at all  :confused:
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #6 on: March 21, 2012, 10:54:57 pm »
cheers james, and i will have to check guy who fitted the brakes originally put them on and i just got them bunged back on when put the summer rubber ans monza back on
« Reply #7 on: March 21, 2012, 11:05:49 pm »
I thought that the NQSBBK was designed to fit without spacing?
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #8 on: March 22, 2012, 09:21:47 am »
yeah me too, I know Dave says you can get the larger 996 turbo claipers under BBS VZ but my Monza Detroit (now refurbed to look like Shadows) do not fit without the spacers
Offline Russ_leeds
« Reply #9 on: March 22, 2012, 10:50:59 am »
I thought that until I got mine fitted. For monza 2s you need a minimum of a 3mm spacer. That's what I have and it's really close
Black 2007 gti, 18' monza 2, sat-nav, highline, i-pod dock, armrest, 35mm H&R springs, WALK, BCS tbe, autotech front and rear arbs, ITG maxogen, NQSBBK... and more to come
Offline Deako
  • -Given: 38
  • -Receive: 44
  • Eat, Sleep....VAG
« Reply #10 on: March 22, 2012, 10:57:54 am »
I have to run 15mm with 17" Monzas on the Polo.  :sad1: And the replacement BBS RK2 504 Splits i brought at ET35 dont clear them either. TD Pro Race 1.2 are basically my only cheap option to not have to run spacers.
#1493
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #11 on: March 22, 2012, 10:07:48 pm »
is there any negatives removing the screw? presumably it was put there for a reason??
Offline gazbutS3
« Reply #12 on: March 22, 2012, 10:13:16 pm »
no negatives at all, you can tuck the liner up behind the lug that held the screw and it does the same job. Your northwest based aren't you? if you need a hand give us a shout :happy2:
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #13 on: March 22, 2012, 10:20:13 pm »
yeah not too far from you Gaz, you in Bolton right? I go there for the 4 wheel alignment at Nigel Langs, will give u shout if need be  :happy2:
Offline gazbutS3
« Reply #14 on: March 22, 2012, 10:24:18 pm »
yep, Bolton, use Nigel Langs myself, like I said if u need a lift doin the arch mod thing pop round and I'll do it for you :smiley:
